Help in Xbee??
I need helping in xbee, i made a simple project led and potentiometer using xbee (wireless) "the potentiometer controls the intensity of light of the led" , but it doesn't work>>
Can anyone tell me if the code is right or what??
// Sample code for sending potentiometer values
int val;
int new_val;
// start serial port at 19200 bps
Serial.begin(19200);
// read analog input
val = analogRead(0);
// remap values
new_val = map(val, 0, 1023, 253, 0);
Serial.write(254);     //SYNC char
Serial.write(new_val);
delay(150);
// RECIEVER
byte incomingByte,pot;
pinMode (5, OUTPUT);  // set led pin 5 to output
delay(100);
 if (Serial.available()) {   // is there any information available on serial port ?
incomingByte = Serial.read(); // assign bytes to the variable ‘incomingByte’
Serial.print(int(incomingByte));
if ((int(incomingByte) == 252)) {
pot = Serial.read();
Serial.print("Pot = ");
Serial.print(int(pot)); //print the values of pot on serial monitor
analogWrite (5, pot); //pwm led according to pot values
How are we supposed to help if you don't tell us what doesn't work?
The Potentiometer in serial monitor >> work , but the led doesn't work!!!
and i made a connection between to xbees and work (TX and RX) by using XCTU program.
