im looking for help and guidance incorporating a button into this code, for use with Arduino, Sonoff and 8266 boards.
i have this running and the relay switching on comand, but i need the button and debounce and i dont know how you do it.
hi !
if I understand well, you want the button to activate the relay ?
eric
sorry for the late reply, yes.
i want the sonoff to work as a wemo switch and have the button work aswell
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <WiFiUDP.h>
const char* ssid = "0000"; // your network SSID (name)
const char* pass = "0000"; // your network password
const char* friendlyName = "Arduino"; // Alexa will use this name to identify your device
const char* serialNumber = "221517K0101768"; // anything will do
const char* uuid = "904bfa3c-1de2-11v2-8728-fd8eebaf492d"; // anything will do
// Multicast declarations
IPAddress ipMulti(239, 255, 255, 250);
const unsigned int portMulti = 1900;
const unsigned int webserverPort = 9876;
// Witty Cloud Board specifc pins
const int LED_PIN = 12;
//int status = WL_IDLE_STATUS;
WiFiUDP Udp;
byte packetBuffer[512]; //buffer to hold incoming and outgoing packets
ESP8266WebServer server(webserverPort);
// UDP Multicast Server
char* getDateString()
//Doesn't matter which date & time, will work
//Optional: replace with NTP Client implementation
return "Wed, 29 Jun 2016 00:13:46 GMT";
void responseToSearchUdp(IPAddress& senderIP, unsigned int senderPort)
Serial.println("responseToSearchUdp");
//This is absolutely neccessary as Udp.write cannot handle IPAddress or numbers correctly like Serial.print
IPAddress myIP = WiFi.localIP();
char ipChar[20];
snprintf(ipChar, 20, "%d.%d.%d.%d", myIP[0], myIP[1], myIP[2], myIP[3]);
char portChar[7];
snprintf(portChar, 7, ":%d", webserverPort);
Udp.beginPacket(senderIP, senderPort);
Udp.write("HTTP/1.1 200 OK\r\n");
Udp.write("CACHE-CONTROL: max-age=86400\r\n");
Udp.write("DATE: ");
Udp.write(getDateString());
Udp.write("\r\n");
Udp.write("EXT:\r\n");
Udp.write("LOCATION: ");
Udp.write("http://");
Udp.write(ipChar);
Udp.write(portChar);
Udp.write("/setup.xml\r\n");
Udp.write("OPT: "http://schemas.upnp.org/upnp/1/0/\"); ns=01\r\n");
Udp.write("01-NLS: ");
Udp.write(uuid);
Udp.write("\r\n");
Udp.write("SERVER: Unspecified, UPnP/1.0, Unspecified\r\n");
Udp.write("X-User-Agent: redsonic\r\n");
Udp.write("ST: urn:Belkin:device:\r\n");
Udp.write("USN: uuid:Socket-1_0-");
Udp.write(serialNumber);
Udp.write(":Belkin:device:\r\n");
Udp.write("\r\n");
Udp.endPacket();
void UdpMulticastServerLoop()
int numBytes = Udp.parsePacket();
if (numBytes <= 0)
return;
IPAddress senderIP = Udp.remoteIP();
unsigned int senderPort = Udp.remotePort();
// read the packet into the buffer
Udp.read(packetBuffer, numBytes);
// print out the received packet
//Serial.write(packetBuffer, numBytes);
// check if this is a M-SEARCH for WeMo device
String request = String((char *)packetBuffer);
int mSearchIndex = request.indexOf("M-SEARCH");
int mBelkinIndex = request.indexOf("urn:Belkin:device:"); //optional
if (mSearchIndex < 0 || mBelkinIndex < 0)
return;
// send a reply, to the IP address and port that sent us the packet we received
responseToSearchUdp(senderIP, senderPort);
// HTTP Server
void handleRoot()
Serial.println("handleRoot");
server.send(200, "text/plain", "Tell Alexa to discover devices");
void handleSetupXml()
Serial.println("handleSetupXml");
String body = "<?xml version=\"1.0\"?>\r\n";
body += "\r\n";
body += " \r\n";
body += " urn:OriginallyUS:device:controllee:1\r\n";
body += " ";
body += friendlyName;
body += "\r\n";
body += " Belkin International Inc.\r\n";
body += " Emulated Socket\r\n";
body += " 3.1415\r\n";
body += " uuid:Socket-1_0-";
body += serialNumber;
body += "\r\n";
body += " \r\n";
body += "";
String header = "HTTP/1.1 200 OK\r\n";
header += "Content-Type: text/xml\r\n";
header += "Content-Length: ";
header += body.length();
header += "\r\n";
header += "Date: ";
header += getDateString();
header += "\r\n";
header += "X-User-Agent: redsonic\r\n";
header += "SERVER: Unspecified, UPnP/1.0, Unspecified\r\n";
header += "connection: close\r\n";
header += "LAST-MODIFIED: Sat, 01 Jan 2000 00:00:00 GMT\r\n";
header += "\r\n";
header += body;
Serial.println(header);
server.sendContent(header);
void handleUpnpControl()
Serial.println("handleUpnpControl");
//Extract raw body
//Because there is a '=' before "1.0", it will give the following:
//"1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1">1</u:SetBinaryState></s:Body></s:Envelope>
String body = server.arg(0);
//Check valid request
boolean isOn = body.indexOf("1") >= 0;
boolean isOff = body.indexOf("0") >= 0;
boolean isValid = isOn || isOff;
if (!isValid) {
Serial.println("Bad request from Amazon Echo");
Serial.println(body);
server.send(400, "text/plain", "Bad request from Amazon Echo");
return;
//On/Off Logic
if (isOn) {
digitalWrite(LED_PIN, 1);
Serial.println("Alexa is asking to turn ON a device");
server.send(200, "text/plain", "Turning ON device");
else {
digitalWrite(LED_PIN, 0);
Serial.println("Alexa is asking to turn OFF a device");
server.send(200, "text/plain", "Turning OFF device");
void handleNotFound()
Serial.println("handleNotFound()");
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++) {
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
// Initialize LED pin
pinMode(LED_PIN, OUTPUT);
// setting up Station AP
WiFi.begin(ssid, pass);
// Wait for connect to AP
Serial.print("[Connecting to ");
Serial.print(ssid);
Serial.print("]...");
int tries=0;
delay(200);
Serial.print(".");
tries++;
if (tries > 50)
// print your WiFi info
IPAddress ip = WiFi.localIP();
Serial.print("Connected to ");
Serial.print(WiFi.SSID());
Serial.print(" with IP: ");
Serial.println(ip);
//UDP Server
Udp.beginMulticast(WiFi.localIP(), ipMulti, portMulti);
Serial.print("Udp multicast server started at ");
Serial.print(ipMulti);
Serial.print(":");
Serial.println(portMulti);
//Web Server
server.on("/", handleRoot);
server.on("/setup.xml", handleSetupXml);
server.on("/upnp/control/basicevent1", handleUpnpControl);
server.onNotFound(handleNotFound);
server.begin();
Serial.print("HTTP server started on port ");
Serial.println(webserverPort);
UdpMulticastServerLoop(); //UDP multicast receiver
server.handleClient(); //Webserver
got this up and running on the sonoff but it needs the button putting in. also some time it turns off after 30mins or so.
Hey Shooter66six, did you get it fix? I have same problem, it restarts after 30-45 minutes. I tried to narrow down the cause by tweaking code but no luck. I asked for help on GITHUB forum but no one cared and no answer from anyone. If you have some updates would like to share? Thanks in advance.
