Help interfacing Parallax Altimeter MS5607 with Arduino SPI - From the I2C code
Hello, I'm stucked in this issue 5 months ago, I really need help, this is the problem, I have to connect the Altimeter MS5607 with my Arduino UNO and using SPI, after trying so many times, I'm really MAD! haha
I think there is a way if I start from the I2C code (I'll paste the example for I2C that works, files taken from Microcontroller KickStarts | LEARN.PARALLAX.COM ):
I really need it to be using SPI Protocoll
I have it connected like this:
Altimeter Arduino pin
CS 10
SDO 12
SDA 11
SCL 13
PS GND
VIN +5
GND GND
Here are the two files with I2C code:
Altimeter_Arduino_10.ino
#include <Wire.h>#include "IntersemaBaro.h"
Intersema::BaroPressure_MS5607B baro(true);
    baro.init();
  int alt = baro.getHeightCentiMeters();
  Serial.print("Centimeters: ");
  Serial.print((float)(alt));
  Serial.print(", Feet: ");
  Serial.println((float)(alt) / 30.48);
  delay(400);
the other file is attached named: IntersemaBaro.h (this is the important file)
I need to connect it using SPI for my project, perhaps from the I2C code we can get the logic to make the communication for SPI.
Any ideas?
Thank you
IntersemaBaro.h (9 KB)
The datasheet tells you what to do:
http://www.parallax.com/portals/0/downloads/docs/prod/sens/29124-AltimeterDatasheet.pdf
Thanks, and I know, the problem is that I have tryed with some code without success:
I think I'm missing some parameters specified in the datasheet
Circuit:
 SCK: pin 13
 MISO: pin 12
 MOSI: pin 11
 SS: pin 10
const int ss = 10;
#include <SPI.h>
//3 bytes to get the 24 bit adc read
byte byte1;
byte byte2;
byte byte3;
  pinMode(ss, OUTPUT);
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  if (Serial.available() > 0) {
    byte incomingByte = Serial.read();
    switch (incomingByte){
    case '0':
      read_alt();
    } //endswitch
  }//enif
}//endloop
void read_alt()
  //READ Altimeter
  digitalWrite(ss, LOW);
  delay(100);
  SPI.transfer(0x50); //ADC conversion command
  delay(1);
  // and store read data into three bytes
  byte1 = SPI.transfer(0x00);//ADC conversion read command, first 8 bits
  byte2 = SPI.transfer(0x00);//ADC conversion read command, second 8 bits
  byte3 = SPI.transfer(0x00);//ADC conversion read command, third 8 bits
  //release chip, signal end transfer
  digitalWrite(ss, HIGH);
  //print the 3 bytes in serial
  Serial.println(byte1, BIN);
  Serial.println(byte2, BIN);
  Serial.println(byte3, BIN);
That's why I think, starting from the I2C code.
Any ideas? need help on this one please!
Daniel
danidub:
What results do you get when you run that sketch?
Still looking for the answer?
Hint:
Keep shifting the SPI buffer with a null value instead of the ADC Read command!
