Help: Invalid library found in
I tried to add a library manually via the directions I found, but it crashed.
Now I am getting this error with every compile.
Is there some way to manually remove the library attempt ?
Below is the full error.
Invalid library found in C:\Program Files (x86)\Arduino\libraries\RTClib:
Thank You.
Navigate to
via Explorer (Windows) or Finder (Mac), and remove the RTCLib folder.
That worked !
Does that mean the compiler checks all those folders on compile ?
Does every library in that folder get compiled in ?
The C++ compiler does not. The Arduino library discovery system does check all the folders under C:\Program Files (x86)\Arduino\libraries though. This is where the warning about the invalid library came from.
No.
