HELP!! INVERSE KINEMATICS CODE FOR SCARA ROBOT
I'm working on a project that draws whatever user draws. So i need inverse kinematics for the scara robot arm that moves to desired x and y position received from the user input device. Im an computer science engineering student im not that much good at robotics and im a beginner in electronics, this is for my academics project. can someone help me with this.
Example 1: https://www.youtube.com/watch?v=Q86bQxoo9vs
Example 2: https://www.youtube.com/watch?v=ZWgcuEoQOFk&t=23s
Im an computer science engineering student ... this is for my academics project.
Excellent project, but it sounds like you are missing [u]some really important course prerequisites[/u].
Ask your professor which those might be; take the courses, and then you will be in a great position to write the code yourself.
That way you can actually make a contribution to society, rather than ask forum members to do your work for you.
Actually im at the end of the semester so i cant take courses right now. in my department they dont offer robotics or electronics courses for my department. I searched a lot in the internet and tried my things but nothing works and my teachers dont have much knwoledge in this field. I came here for the last try. Im not asking for the whole project just the IK part.
I wrote the below code.
#include<Math.h>
int l1=15,l2=15,x,y;
float teta1,teta2;
void calc_IK(int x_ip,int y_ip);
calc_IK(0.45,0.52);
x=x_ip;
y=y_ip;
teta2=acos(((xx)+(xx)-(l1l1)-(l2l2))/(2l1l2));
teta1=-((l2*sin(teta2)x+(l1+l2cos(teta2))y)/((l2sin(teta2)y+(l1+l2cos(teta2))*y)));
Serial.println(degrees(teta1));
Serial.println(degrees(teta2));
Please use code tags </> to present code.
I didn’t check your formulas, just two hints:
Use “const” with constant values, i.e. for I1 and I2 if these are constants.
calc_IK should accept floating point values, not integers. I’d drop the global x and y variables, and declare
void calc_IK(float x, float y);
And I’d add code to transform the calculated angles into the resulting positions of the robot arm, just to find out whether your calculations are correct.
