Help isolating individual bytes from a double or float variable
Hi all
I'm struggling to get a section of code working on my Arduino Uno.
I have a double variable (eg. var = 3.14) and would like to isolate the individual bytes.
I'm aware the Arduino uses 4 bytes to store this value and I would like to take the individual hex data and store in 4 separate variables as described below.
Example: double var = x.xx (00000000 11111111 22222222 33333333) byte new0 = 0xFF (00000000) byte new1 = 0xFF (11111111) byte new2 = 0xFF (22222222) byte new3 = 0xFF (33333333)
The bytes are eventually going to end up in LabVIEW (Via XBEE Packets) in which I will reconstruct the bytes as a double.
Any help with this will be much appreciated.
Good luck, but you can use a union.
union pick_a_part { float a; byte b[4]} val;
val.a = float_val; byte b1 = val.b[0];
Frankly, I would just send text. No endian issues, et al.
I haven’t tested it, but here’s what I’ve come up with:
float f = 3.14159; // or whatever
// Caution:
// In the process of conversion, the original float will be destroyed.
// This code does not support infinities, NANs, or denormal numbers.
uint8_t top=0, second=0, third=0, bottom=0;
if (f < 0.0) {
  top=128; // set negative flag
  f=-f; // make positive
if (f > 0.0) {
  top+=67;
  while (f>=512.0) {
    top++; // increase exponent by 2
    f*=0.25; // divide float by 4
  while (f<128.0) {
    top--; // decrease exponent by 2
    f*=4.0; // multiply float by 4
  if (f<256.0) {
    // float is in range 128.0 to 255.9999...
    // so, low bit of exponent should be 0
    second = (uint8_t)f; // integer part of float
    f-=second; // fractional part of float
    second-=128; // clear low bit of exponent
  else {
    // for floats 256.0 to 511.9999...
    f*=0.5; // scale float to range 128.0 to 255.9999...
    // high bit of exponent is now 1, which is how we want it
  // the last two bytes are straightforward
  f*=256.0;
  third=(uint8_t)f;
  f-=third;
  f*=256.0;
  bottom=(uint8_t)f;
// we're done!
The type “double” in LabVIEW is 64 bits (8 bytes).
Another reason to go with ASCII.
check playground - http://playground.arduino.cc/Main/IEEE754tools
latest - https://github.com/RobTillaart/Arduino/tree/master/libraries/IEEE754tools )
