Help joining 2 codes togheter
hello, can anyone help me join these 2 codes togheter? i dont understand much about variables so i want leq_dBA values to be send instead of the float t = dht.readTemperature();
This is the code of the sound meter
#include <driver/i2s.h>
#include "sos-iir-filter.h"
// Configuration
#define LEQ_PERIOD        1           // second(s)
#define WEIGHTING         A_weighting // Also avaliable: 'C_weighting' or 'None' (Z_weighting)
#define LEQ_UNITS         "LAeq"      // customize based on above weighting used
#define DB_UNITS          "dBA"       // customize based on above weighting used
#define USE_DISPLAY       1
// NOTE: Some microphones require at least DC-Blocker filter
#define MIC_EQUALIZER     INMP441   // See below for defined IIR filters or set to 'None' to disable
#define MIC_OFFSET_DB     3.0103      // Default offset (sine-wave RMS vs. dBFS). Modify this value for linear calibration
// Customize these values from microphone datasheet
#define MIC_SENSITIVITY   -26         // dBFS value expected at MIC_REF_DB (Sensitivity value from datasheet)
#define MIC_REF_DB        94.0        // Value at which point sensitivity is specified in datasheet (dB)
#define MIC_OVERLOAD_DB   116.0       // dB - Acoustic overload point
#define MIC_NOISE_DB      29          // dB - Noise floor
#define MIC_BITS          24          // valid number of bits in I2S data
#define MIC_CONVERT(s)    (s >> (SAMPLE_BITS - MIC_BITS))
#define MIC_TIMING_SHIFT  0           // Set to one to fix MSB timing for some microphones, i.e. SPH0645LM4H-x
// Calculate reference amplitude value at compile time
constexpr double MIC_REF_AMPL = pow(10, double(MIC_SENSITIVITY)/20) * ((1<<(MIC_BITS-1))-1);
// I2S pins - Can be routed to almost any (unused) ESP32 pin.
//            SD can be any pin, inlcuding input only pins (36-39).
//            SCK (i.e. BCLK) and WS (i.e. L/R CLK) must be output capable pins
// Below ones are just example for my board layout, put here the pins you will use
#define I2S_WS            18
#define I2S_SCK           23
#define I2S_SD            19
// I2S peripheral to use (0 or 1)
#define I2S_PORT          I2S_NUM_0
// Setup your display library (and geometry) here
#if (USE_DISPLAY > 0)
  // ThingPulse/esp8266-oled-ssd1306, you may need the latest source and PR#198 for 64x48
  #include <SSD1306Wire.h>
  #define OLED_GEOMETRY     GEOMETRY_128_64
  //#define OLED_GEOMETRY GEOMETRY_128_32
  //#define OLED_GEOMETRY GEOMETRY_128_64
  #define OLED_FLIP_V       1
  SSD1306Wire display(0x3c, SDA, SCL, OLED_GEOMETRY);
#endif
// IIR Filters
// DC-Blocker filter - removes DC component from I2S data
// See: https://www.dsprelated.com/freebooks/filters/DC_Blocker.html
// a1 = -0.9992 should heavily attenuate frequencies below 10Hz
SOS_IIR_Filter DC_BLOCKER = {
  gain: 1.0,
  sos: {{-1.0, 0.0, +0.9992, 0}}
// Equalizer IIR filters to flatten microphone frequency response
// See respective .m file for filter design. Fs = 48Khz.
// Filters are represented as Second-Order Sections cascade with assumption
// that b0 and a0 are equal to 1.0 and 'gain' is applied at the last step
// B and A coefficients were transformed with GNU Octave:
// [sos, gain] = tf2sos(B, A)
// See: https://www.dsprelated.com/freebooks/filters/Series_Second_Order_Sections.html
// NOTE: SOS matrix 'a1' and 'a2' coefficients are negatives of tf2sos output
// TDK/InvenSense ICS-43434
// Datasheet: https://www.invensense.com/wp-content/uploads/2016/02/DS-000069-ICS-43434-v1.1.pdf
// B = [0.477326418836803, -0.486486982406126, -0.336455844522277, 0.234624646917202, 0.111023257388606];
// A = [1.0, -1.93073383849136326, 0.86519456089576796, 0.06442838283825100, 0.00111249298800616];
SOS_IIR_Filter ICS43434 = {
  gain: 0.477326418836803,
  sos: { // Second-Order Sections {b1, b2, -a1, -a2}
   {+0.96986791463971267, 0.23515976355743193, -0.06681948004769928, -0.00111521990688128},
   {-1.98905931743624453, 0.98908924206960169, +1.99755331853906037, -0.99755481510122113}
// TDK/InvenSense ICS-43432
// Datasheet: https://www.invensense.com/wp-content/uploads/2015/02/ICS-43432-data-sheet-v1.3.pdf
// B = [-0.45733702338341309   1.12228667105574775  -0.77818278904413563, 0.00968926337978037, 0.10345668405223755]
// A = [1.0, -3.3420781082912949, 4.4033694320978771, -3.0167072679918010, 1.2265536567647031, -0.2962229189311990, 0.0251085747458112]
SOS_IIR_Filter ICS43432 = {
  gain: -0.457337023383413,
    {-0.544047931916859, -0.248361759321800, +0.403298891662298, -0.207346186351843},
    {-1.909911869441421, +0.910830292683527, +1.790285722826743, -0.804085812369134},
    {+0.000000000000000, +0.000000000000000, +1.148493493802252, -0.150599527756651}
// TDK/InvenSense INMP441
// Datasheet: https://www.invensense.com/wp-content/uploads/2015/02/INMP441.pdf
// B ~= [1.00198, -1.99085, 0.98892]
// A ~= [1.0, -1.99518, 0.99518]
SOS_IIR_Filter INMP441 = {
  gain: 1.00197834654696,
    {-1.986920458344451, +0.986963226946616, +1.995178510504166, -0.995184322194091}
// Infineon IM69D130 Shield2Go
// Datasheet: https://www.infineon.com/dgdl/Infineon-IM69D130-DS-v01_00-EN.pdf?fileId=5546d462602a9dc801607a0e46511a2e
// B ~= [1.001240684967527, -1.996936108836337, 0.995703101823006]
// A ~= [1.0, -1.997675693595542, 0.997677044195563]
// With additional DC blocking component
SOS_IIR_Filter IM69D130 = {
  gain: 1.00124068496753,
  sos: {
    {-1.0, 0.0, +0.9992, 0}, // DC blocker, a1 = -0.9992
    {-1.994461610298131, 0.994469278738208, +1.997675693595542, -0.997677044195563}
// Knowles SPH0645LM4H-B, rev. B
// https://cdn-shop.adafruit.com/product-files/3421/i2S+Datasheet.PDF
// B ~= [1.001234, -1.991352, 0.990149]
// A ~= [1.0, -1.993853, 0.993863]
SOS_IIR_Filter SPH0645LM4H_B_RB = {
  gain: 1.00123377961525,
    {-1.988897663539382, +0.988928479008099, +1.993853376183491, -0.993862821429572}
// Weighting filters
// A-weighting IIR Filter, Fs = 48KHz
// (By Dr. Matt L., Source: https://dsp.stackexchange.com/a/36122)
// B = [0.169994948147430, 0.280415310498794, -1.120574766348363, 0.131562559965936, 0.974153561246036, -0.282740857326553, -0.152810756202003]
// A = [1.0, -2.12979364760736134, 0.42996125885751674, 1.62132698199721426, -0.96669962900852902, 0.00121015844426781, 0.04400300696788968]
SOS_IIR_Filter A_weighting = {
  gain: 0.169994948147430,
    {-2.00026996133106, +1.00027056142719, -1.060868438509278, -0.163987445885926},
    {+4.35912384203144, +3.09120265783884, +1.208419926363593, -0.273166998428332},
    {-0.70930303489759, -0.29071868393580, +1.982242159753048, -0.982298594928989}
// C-weighting IIR Filter, Fs = 48KHz
// Designed by invfreqz curve-fitting, see respective .m file
// B = [-0.49164716933714026, 0.14844753846498662, 0.74117815661529129, -0.03281878334039314, -0.29709276192593875, -0.06442545322197900, -0.00364152725482682]
// A = [1.0, -1.0325358998928318, -0.9524000181023488, 0.8936404694728326   0.2256286147169398  -0.1499917107550188, 0.0156718181681081]
SOS_IIR_Filter C_weighting = {
  gain: -0.491647169337140,
  sos: {
    {+1.4604385758204708, +0.5275070373815286, +1.9946144559930252, -0.9946217070140883},
    {+0.2376222404939509, +0.0140411206016894, -1.3396585608422749, -0.4421457807694559},
    {-2.0000000000000000, +1.0000000000000000, +0.3775800047420818, -0.0356365756680430}
// Sampling
#define SAMPLE_RATE       48000 // Hz, fixed to design of IIR filters
#define SAMPLE_BITS       32    // bits
#define SAMPLE_T          int32_t
#define SAMPLES_SHORT     (SAMPLE_RATE / 8) // ~125ms
#define SAMPLES_LEQ       (SAMPLE_RATE * LEQ_PERIOD)
#define DMA_BANK_SIZE     (SAMPLES_SHORT / 16)
#define DMA_BANKS         32
// Data we push to 'samples_queue'
struct sum_queue_t {
  // Sum of squares of mic samples, after Equalizer filter
  float sum_sqr_SPL;
  // Sum of squares of weighted mic samples
  float sum_sqr_weighted;
  // Debug only, FreeRTOS ticks we spent processing the I2S data
  uint32_t proc_ticks;
QueueHandle_t samples_queue;
// Static buffer for block of samples
float samples[SAMPLES_SHORT] __attribute__((aligned(4)));
// I2S Microphone sampling setup
void mic_i2s_init() {
  // Setup I2S to sample mono channel for SAMPLE_RATE * SAMPLE_BITS
  // NOTE: Recent update to Arduino_esp32 (1.0.2 -> 1.0.3)
  //       seems to have swapped ONLY_LEFT and ONLY_RIGHT channels
  const i2s_config_t i2s_config = {
    mode: i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_RX),
    sample_rate: SAMPLE_RATE,
    bits_per_sample: i2s_bits_per_sample_t(SAMPLE_BITS),
    channel_format: I2S_CHANNEL_FMT_ONLY_RIGHT,
    communication_format: i2s_comm_format_t(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
    intr_alloc_flags: ESP_INTR_FLAG_LEVEL1,
    dma_buf_count: DMA_BANKS,
    dma_buf_len: DMA_BANK_SIZE,
    use_apll: true,
    tx_desc_auto_clear: false,
    fixed_mclk: 0
  // I2S pin mapping
  const i2s_pin_config_t pin_config = {
    bck_io_num:   I2S_SCK,
    ws_io_num:    I2S_WS,
    data_out_num: -1, // not used
    data_in_num:  I2S_SD
  i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
  #if (MIC_TIMING_SHIFT > 0)
    // Undocumented (?!) manipulation of I2S peripheral registers
    // to fix MSB timing issues with some I2S microphones
    REG_SET_BIT(I2S_TIMING_REG(I2S_PORT), BIT(9));
    REG_SET_BIT(I2S_CONF_REG(I2S_PORT), I2S_RX_MSB_SHIFT);
  #endif
  i2s_set_pin(I2S_PORT, &pin_config);
  //FIXME: There is a known issue with esp-idf and sampling rates, see:
  //       https://github.com/espressif/esp-idf/issues/2634
  //       In the meantime, the below line seems to set sampling rate at ~47999.992Hz
  //       fifs_req=24576000, sdm0=149, sdm1=212, sdm2=5, odir=2 -> fifs_reached=24575996
  //NOTE:  This seems to be fixed in ESP32 Arduino 1.0.4, esp-idf 3.2
  //       Should be safe to remove...
  //#include <soc/rtc.h>
  //rtc_clk_apll_enable(1, 149, 212, 5, 2);
// I2S Reader Task
// Rationale for separate task reading I2S is that IIR filter
// processing cam be scheduled to different core on the ESP32
// while main task can do something else, like update the
// display in the example
// As this is intended to run as separate hihg-priority task,
// we only do the minimum required work with the I2S data
// until it is 'compressed' into sum of squares
// FreeRTOS priority and stack size (in 32-bit words)
#define I2S_TASK_PRI   4
#define I2S_TASK_STACK 2048
void mic_i2s_reader_task(void* parameter) {
  mic_i2s_init();
  // Discard first block, microphone may have startup time (i.e. INMP441 up to 83ms)
  size_t bytes_read = 0;
  i2s_read(I2S_PORT, &samples, SAMPLES_SHORT * sizeof(int32_t), &bytes_read, portMAX_DELAY);
  while (true) {
    // Block and wait for microphone values from I2S
    // Data is moved from DMA buffers to our 'samples' buffer by the driver ISR
    // and when there is requested ammount of data, task is unblocked
    // Note: i2s_read does not care it is writing in float[] buffer, it will write
    //       integer values to the given address, as received from the hardware peripheral.
    i2s_read(I2S_PORT, &samples, SAMPLES_SHORT * sizeof(SAMPLE_T), &bytes_read, portMAX_DELAY);
    TickType_t start_tick = xTaskGetTickCount();
    // Convert (including shifting) integer microphone values to floats,
    // using the same buffer (assumed sample size is same as size of float),
    // to save a bit of memory
    SAMPLE_T* int_samples = (SAMPLE_T*)&samples;
    for(int i=0; i<SAMPLES_SHORT; i++) samples[i] = MIC_CONVERT(int_samples[i]);
    sum_queue_t q;
    // Apply equalization and calculate Z-weighted sum of squares,
    // writes filtered samples back to the same buffer.
    q.sum_sqr_SPL = MIC_EQUALIZER.filter(samples, samples, SAMPLES_SHORT);
    // Apply weighting and calucate weigthed sum of squares
    q.sum_sqr_weighted = WEIGHTING.filter(samples, samples, SAMPLES_SHORT);
    // Debug only. Ticks we spent filtering and summing block of I2S data
    q.proc_ticks = xTaskGetTickCount() - start_tick;
    // Send the sums to FreeRTOS queue where main task will pick them up
    // and further calcualte decibel values (division, logarithms, etc...)
    xQueueSend(samples_queue, &q, portMAX_DELAY);
// Setup and main loop
// Note: Use doubles, not floats, here unless you want to pin
//       the task to whichever core it happens to run on at the moment
  // If needed, now you can actually lower the CPU frquency,
  // i.e. if you want to (slightly) reduce ESP32 power consumption
  setCpuFrequencyMhz(80); // It should run as low as 80MHz
  Serial.begin(112500);
  delay(1000); // Safety
    display.init();
    #if (OLED_FLIP_V > 0)
      display.flipScreenVertically();
    #endif
    display.setFont(ArialMT_Plain_16);
  #endif
  // Create FreeRTOS queue
  samples_queue = xQueueCreate(8, sizeof(sum_queue_t));
  // Create the I2S reader FreeRTOS task
  // NOTE: Current version of ESP-IDF will pin the task
  //       automatically to the first core it happens to run on
  //       (due to using the hardware FPU instructions).
  //       For manual control see: xTaskCreatePinnedToCore
  xTaskCreate(mic_i2s_reader_task, "Mic I2S Reader", I2S_TASK_STACK, NULL, I2S_TASK_PRI, NULL);
  sum_queue_t q;
  uint32_t Leq_samples = 0;
  double Leq_sum_sqr = 0;
  double Leq_dB = 0;
  // Read sum of samaples, calculated by 'i2s_reader_task'
  while (xQueueReceive(samples_queue, &q, portMAX_DELAY)) {
    // Calculate dB values relative to MIC_REF_AMPL and adjust for microphone reference
    double short_RMS = sqrt(double(q.sum_sqr_SPL) / SAMPLES_SHORT);
    double short_SPL_dB = MIC_OFFSET_DB + MIC_REF_DB + 20 * log10(short_RMS / MIC_REF_AMPL);
    // In case of acoustic overload or below noise floor measurement, report infinty Leq value
    if (short_SPL_dB > MIC_OVERLOAD_DB) {
      Leq_sum_sqr = INFINITY;
    } else if (isnan(short_SPL_dB) || (short_SPL_dB < MIC_NOISE_DB)) {
      Leq_sum_sqr = -INFINITY;
    // Accumulate Leq sum
    Leq_sum_sqr += q.sum_sqr_weighted;
    Leq_samples += SAMPLES_SHORT;
    // When we gather enough samples, calculate new Leq value
    if (Leq_samples >= SAMPLE_RATE * LEQ_PERIOD) {
      double Leq_RMS = sqrt(Leq_sum_sqr / Leq_samples);
      Leq_dB = MIC_OFFSET_DB + MIC_REF_DB + 20 * log10(Leq_RMS / MIC_REF_AMPL);
      Leq_sum_sqr = 0;
      Leq_samples = 0;
      // Serial output, customize (or remove) as needed
      Serial.printf("%.1f\n", Leq_dB);
      // Debug only
      //Serial.printf("%u processing ticks\n", q.proc_ticks);
      // Example code that displays the measured value.
      // You should customize the below code for your display
      // and display library used.
      display.clear();
      // It is important to somehow notify when the deivce is out of its range
      // as the calculated values are very likely with big error
      if (Leq_dB > MIC_OVERLOAD_DB) {
        // Display 'Overload' if dB value is over the AOP
        display.drawString(0, 24, "Overload");
      } else if (isnan(Leq_dB) || (Leq_dB < MIC_NOISE_DB)) {
        // Display 'Low' if dB value is below noise floor
        display.drawString(0, 24, "Low");
      // The 'short' Leq line
      double short_Leq_dB = MIC_OFFSET_DB + MIC_REF_DB + 20 * log10(sqrt(double(q.sum_sqr_weighted) / SAMPLES_SHORT) / MIC_REF_AMPL);
      uint16_t len = min(max(0, int(((short_Leq_dB - MIC_NOISE_DB) / MIC_OVERLOAD_DB) * (display.getWidth()-1))), display.getWidth()-1);
      display.drawHorizontalLine(0, 0, len);
      display.drawHorizontalLine(0, 1, len);
      display.drawHorizontalLine(0, 2, len);
      // The Leq numeric decibels
      display.drawString(0, 4, String(Leq_dB, 1) + " " + DB_UNITS);
      display.display();
    #endif // USE_DISPLAY
  // Nothing here..
and this one is from the iot temperature sensor
#include <WiFi.h>
#include <HTTPClient.h>
#include "DHT.h"
#define DHTPIN 5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
const char* ssid = "your WiFi ssid";
const char* password = "Your WiFi password";
// Domain Name with full URL Path for HTTP POST Request
const char* serverName = "http://api.thingspeak.com/update";
// write API Key provided by thingspeak
String apiKey = "your write API key";
  WiFi.begin(ssid, password);
  dht.begin();
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  if(WiFi.status()== WL_CONNECTED){
      WiFiClient client;
      HTTPClient http;
      delay(10000); // wait for 10 seconds
     //float h = dht.readHumidity();
      if (isnan(t)) {
       Serial.println(F("Failed to read from DHT sensor!"));
       return;
      // Your Domain name with URL path or IP address with path
      http.begin(client, serverName);
      // Specify content-type header
      http.addHeader("Content-Type", "application/x-www-form-urlencoded");
      // Data to send with HTTP POST
      String httpRequestData = "api_key=" + apiKey + "&field1=" + String(t);
      // Send HTTP POST request
      int httpResponseCode = http.POST(httpRequestData);
      // If you need an HTTP request with a content type: application/json, use the following:
      http.addHeader("Content-Type", "application/json");
      // JSON data to send with HTTP POST
      String httpRequestData = "{\"api_key\":\"" + apiKey + "\",\"field1\":\"" + String(random(40)) + "\"}";
      int httpResponseCode = http.POST(httpRequestData);*/
      Serial.print("HTTP Response code: ");
      Serial.println(httpResponseCode);
      http.end();
    else {
      Serial.println("WiFi Disconnected");
I think you have a lot more than you can currently work with. Get a copy of the Arduino Cookbook, skim it cover to cover, then read applicable sections. Also spend some time following some relatte arduino tutorials. Make an attempt to put the codes together and sort out the hardware connections. Also generate a schematic as to how this goes together.
see combining sketches
So this is what ive tryed untill now, but it shows me the db output on the serial monitor so far and not sendind me the dado0 random numbers to the thingsboard, can someone give me a hand? later the dado0 will be the leq_dB
#include <WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include <ArduinoOTA.h>
const char* ssid         = "NOS_DB46A3";
const char* password     = "E640421C5C";
const char* mqttServer   = "thingsboard.cloud";
const int   mqttPort     = 1883;
const char* mqttUser     = "soundmeter";       //User name
const char* mqttPassword = "esp32";        //Password
const char* mqttClient   = "soundmeteresp32"; //ID
 WiFiClient espClient;
PubSubClient client(espClient);
const int capacity = JSON_OBJECT_SIZE(21);
StaticJsonDocument<capacity> doc;
int contador = 1;
char mensagem[30];
// Configuration
#define I2S_WS            18
#define I2S_SCK           23
#define I2S_SD            19
// IIR Filters
  gain: 1.0,
  sos: {
  sos: {
// Sampling
  float sum_sqr_SPL;
    use_apll: true,
    fixed_mclk: 0
  // I2S pin mapping
    ws_io_num:    I2S_WS,
    data_in_num:  I2S_SD
  #endif
// I2S Reader Task
  mic_i2s_init();
  while (true) {
    sum_queue_t q;
    Serial.println("Iniciando conexao com a rede WiFi..");
  Serial.println("Conectado na rede WiFi!");
  sum_queue_t q;
  double Leq_dB = 0;
      Leq_sum_sqr = 0;
      Leq_samples = 0;
      // Debug only
   reconectabroker();
  doc["Dado0"] = random(100);
  String string1 = "v1/devices/me/telemetry";
  char Buf1[256];  string1.toCharArray(Buf1, 256);
  Serial.println(Buf1);
  char docBuffer1[256];
  size_t n = serializeJson(doc, docBuffer1);
  Serial.println(docBuffer1);
  client.publish(Buf1, docBuffer1, n);
  sprintf(mensagem, "MQTT ESP32 - Mensagem no. %d", contador);
  Serial.print("Mensagem enviada: ");
  Serial.println(mensagem);
  client.publish(Buf1, mensagem);
  Serial.println("Mensagem enviada com sucesso...");
  contador++;
void reconectabroker() {
  client.publish("v1/devices/me/telemetry", mensagem);
  char Buf1[256];
  client.setServer(mqttServer, mqttPort);
  while (!client.connected()) {
    Serial.println("Conectando ao broker MQTT...");
    if (client.connect(mqttClient, mqttUser, mqttPassword )) {
      Serial.println("Conectado ao broker!");
    }else {
      Serial.print("Falha na conexao ao broker - Estado: ");
      Serial.println(client.state());
      delay(2000);
Did you not mark your "2 codes" as "solved?"
