So, I know this is an incredibly frequent problem that people seem to experience on here and after endlessly scrolling through this forum searching for answers nothing at all has worked.
I keep getting the "Error opening serial port 'com3'.(port busy)" message when trying to open the serial monitor after compiling my code for a ultrasonic sensor. I've tried most of the suggestions on here and I still get the message.
For some reason I can open the Serial monitor when the code is compiling but not once it has compiled. Also, I have two USB ports on my laptop but they both show up as COM3. I found this unusual.
Any help would be greatly appreciated!
Error message:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Raspberry Pi Pico, 2MB (no FS), 125 MHz, Small (-Os) (standard), Disabled, Disabled, None, Pico SDK"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\sean_\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\sean_\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\sean_\OneDrive\Documents\Arduino\libraries -fqbn=rp2040:rp2040:rpipico:flash=2097152_0,freq=125,opt=Small,rtti=Disabled,dbgport=Disabled,dbglvl=None,usbstack=picosdk -vid-pid=2E8A_00C0 -ide-version=10819 -build-path C:\Users\sean_\AppData\Local\Temp\arduino_build_298198 -warnings=none -build-cache C:\Users\sean_\AppData\Local\Temp\arduino_cache_639404 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.pqt-elf2uf2.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-elf2uf2\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-elf2uf2-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-elf2uf2\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-pioasm.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-pioasm\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-pioasm-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-pioasm\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-mklittlefs.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-mklittlefs\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-mklittlefs-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-mklittlefs\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-gcc.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-gcc-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-python3.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed -prefs=runtime.tools.pqt-python3-1.0.1-base-3a57aed.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed -prefs=runtime.tools.pqt-openocd.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-openocd\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-openocd-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-openocd\1.3.3-a-ed6d983 -verbose C:\Users\sean_\OneDrive\Documents\Arduino\Arduino\Arduino.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\sean_\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\sean_\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\sean_\OneDrive\Documents\Arduino\libraries -fqbn=rp2040:rp2040:rpipico:flash=2097152_0,freq=125,opt=Small,rtti=Disabled,dbgport=Disabled,dbglvl=None,usbstack=picosdk -vid-pid=2E8A_00C0 -ide-version=10819 -build-path C:\Users\sean_\AppData\Local\Temp\arduino_build_298198 -warnings=none -build-cache C:\Users\sean_\AppData\Local\Temp\arduino_cache_639404 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.pqt-elf2uf2.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-elf2uf2\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-elf2uf2-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-elf2uf2\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-pioasm.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-pioasm\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-pioasm-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-pioasm\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-mklittlefs.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-mklittlefs\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-mklittlefs-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-mklittlefs\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-gcc.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-gcc-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-python3.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed -prefs=runtime.tools.pqt-python3-1.0.1-base-3a57aed.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed -prefs=runtime.tools.pqt-openocd.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-openocd\1.3.3-a-ed6d983 -prefs=runtime.tools.pqt-openocd-1.3.3-a-ed6d983.path=C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-openocd\1.3.3-a-ed6d983 -verbose C:\Users\sean_\OneDrive\Documents\Arduino\Arduino\Arduino.ino
Using board 'rpipico' from platform in folder: C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0
Using core 'rp2040' from platform in folder: C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0
Detecting libraries used...
"C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983/bin/arm-none-eabi-g++" -c -Werror=return-type "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/tools/libpico" -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER="Raspberry Pi"" "-DUSB_PRODUCT="Pico"" -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions "-iprefixC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/" "@C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/lib/platform_inc.txt" -fno-rtti -std=gnu++17 -g -w -x c++ -E -CC -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=125000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME="RASPBERRY_PI_PICO"" -DARDUINO_ARCH_RP2040 -Os "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0\cores\rp2040" "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0\variants\rpipico" "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198\sketch\Arduino.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983/bin/arm-none-eabi-g++" -c -Werror=return-type "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/tools/libpico" -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER="Raspberry Pi"" "-DUSB_PRODUCT="Pico"" -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions "-iprefixC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/" "@C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/lib/platform_inc.txt" -fno-rtti -std=gnu++17 -g -w -x c++ -E -CC -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=125000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME="RASPBERRY_PI_PICO"" -DARDUINO_ARCH_RP2040 -Os "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0\cores\rp2040" "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0\variants\rpipico" "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198\sketch\Arduino.ino.cpp" -o "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983/bin/arm-none-eabi-g++" -c -Werror=return-type "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/tools/libpico" -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER="Raspberry Pi"" "-DUSB_PRODUCT="Pico"" -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions "-iprefixC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/" "@C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/lib/platform_inc.txt" -fno-rtti -std=gnu++17 -g -DSERIALUSB_PID=0x000a -DUSBD_MAX_POWER_MA=250 -DF_CPU=125000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME="RASPBERRY_PI_PICO"" -DARDUINO_ARCH_RP2040 -Os "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0\cores\rp2040" "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0\variants\rpipico" "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198\sketch\Arduino.ino.cpp" -o "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198\sketch\Arduino.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\sean_\AppData\Local\Temp\arduino_cache_639404\core\core_07333e4516baf75cbb11ee494af2233c.a
Linking everything together...
"C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed/python3" -I "C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/tools/simplesub.py" --input "C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/lib/memmap_default.ld" --out "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/memmap_default.ld" --sub FLASH_LENGTH 2093056 --sub EEPROM_START 270528512 --sub FS_START 270528512 --sub FS_END 270528512 --sub RAM_LENGTH 256k
"C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983/bin/arm-none-eabi-gcc" -Werror=return-type "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/tools/libpico" -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER="Raspberry Pi"" "-DUSB_PRODUCT="Pico"" -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -Os -u printf_float -u scanf_float -c "C:\Users\sean\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/boot2/boot2_w25q080_2_padded_checksum.S" "-IC:\Users\sean\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/pico-sdk/src/rp2040/hardware_regs/include/" "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/pico-sdk/src/common/pico_binary_info/include" -o "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/boot2.o"
"C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983/bin/arm-none-eabi-g++" "-LC:\Users\sean_\AppData\Local\Temp\arduino_build_298198" -Werror=return-type "-IC:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/tools/libpico" -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSB_VID=0x2e8a -DUSB_PID=0x000a "-DUSB_MANUFACTURER="Raspberry Pi"" "-DUSB_PRODUCT="Pico"" -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -Os -u printf_float -u scanf_float "@C:\Users\sean\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/lib/platform_wrap.txt" -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common "-Wl,--script=C:\Users\sean\AppData\Local\Temp\arduino_build_298198/memmap_default.ld" "-Wl,-Map,C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/Arduino.ino.map" -o "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/Arduino.ino.elf" -Wl,--start-group "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198\sketch\Arduino.ino.cpp.o" "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/..\arduino_cache_639404\core\core_07333e4516baf75cbb11ee494af2233c.a" "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/boot2.o" "C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\hardware\rp2040\1.13.0/lib/libpico.a" -lm -lc -lstdc++ -lc -Wl,--end-group
"C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-elf2uf2\1.3.3-a-ed6d983/elf2uf2" "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/Arduino.ino.elf" "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/Arduino.ino.uf2"
"C:\Users\sean_\OneDrive\Documents\ArduinoData\packages\rp2040\tools\pqt-gcc\1.3.3-a-ed6d983/bin/arm-none-eabi-size" -A "C:\Users\sean_\AppData\Local\Temp\arduino_build_298198/Arduino.ino.elf"
Sketch uses 59032 bytes (2%) of program storage space. Maximum is 2093056 bytes.
Global variables use 11152 bytes (4%) of dynamic memory, leaving 250992 bytes for local variables. Maximum is 262144 bytes.
Error opening serial port 'COM3'. (Port busy)
Resetting COM3
Caught exception during reset!
Converting to uf2, output size: 131584, start address: 0x2000
No drive to deploy.
An error occurred while uploading the sketch
Code Used:
const int triggerPin=5; // Defining pin numbers
const int echoPin=4;
long period; // Defining variables
int distance;
pinMode (triggerPin,OUTPUT);
pinMode (echoPin,INPUT);
digitalWrite(triggerPin,LOW);
delay(2);
digitalWrite(triggerPin,HIGH);
delay(10);
period = pulseIn(echoPin,HIGH);
distance = period*0.034/2;
Serial.print("Distance: ");
Serial.print(distance);
