Help! Keyboard library keeps getting errors
Hello all, I recently bought my first Arduino pro micro to make a make a macro pad for fusion360 shortcuts. But before that I tried to use the keyboard library and HID project library with a rotary encoder. In that code I tried to shift applications with moving rotary encoder right and left, but i seem to have gotten an error. How to correct this
#include "Keyboard.h"
#include "HID-Project.h"
// Rotary Encoder Inputs
#define inputCLK 1
#define inputDT 2
#define inputSW 3
int currentStateCLK;
int previousStateCLK;
int mode = 1;
int maxMode = 4;
void changeMode() {
    mode = (mode % maxMode) + 1;
  // Set encoder pins as inputs
  pinMode (inputCLK,INPUT);
  pinMode (inputDT,INPUT);
  pinMode(inputSW, INPUT_PULLUP);
  // Setup Serial Monitor
  Serial.begin (9600);
  Consumer.begin();
  Keyboard.begin();
  // Read the initial state of inputCLK
  // Assign to previousStateCLK variable
  previousStateCLK = digitalRead(inputCLK);
  // Read the current state of inputCLK
  currentStateCLK = digitalRead(inputCLK);
  // If the previous and the current state of the inputCLK are different then a pulse has occured
  if (currentStateCLK != previousStateCLK){
    // If the inputDT state is different than the inputCLK state then
    // the encoder is rotating counterclockwise
    if (digitalRead(inputDT) != currentStateCLK) {
      rotateRight();
    else {
      rotateLeft();
  // Update previousStateCLK with the current state
  previousStateCLK = currentStateCLK;
        if(!digitalRead(inputSW)) {
            changeMode();
            delay(300);
void rotateLeft() {
  switch(mode) {
    case 1:
      // Increase the volume.
      Consumer.write(MEDIA_VOLUME_UP);
    case 2:
      //Cltr + TAB
      Keyboard.press(KEY_LEFT_CTRL);
      Keyboard.press(KEY_TAB);
      Keyboard.releaseAll();
void rotateRight() {
  switch(mode) {
    case 1:
      // Decrease the volume.
      Consumer.write(MEDIA_VOLUME_DOWN);
    case 2:
      //Cltr + SHIFT + TAB
      Keyboard.press(KEY_LEFT_SHIFT);
After trying to compile the above code , I get the following error:-
In file included from C:\Users\Lenovo\Documents\Arduino\Rotary_Encoder_Multiplex\Rotary_Encoder_Multiplex.ino:1:0:
C:\Users\Lenovo\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:54:27: error: expected identifier before numeric constant
 #define KEY_RETURN        0xB0
e:\arduino ide\arduino-1.8.19-windows\arduino-1.8.19\libraries\hid_project-2.8.4\src\keyboardlayouts\improvedkeylayouts.h:103:5: note: in expansion of macro 'KEY_RETURN'
     KEY_RETURN          = 40, // Alias
C:\Users\Lenovo\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:54:27: error: expected '}' before numeric constant
C:\Users\Lenovo\Documents\Arduino\libraries\Keyboard\src/Keyboard.h:54:27: error: expected unqualified-id before numeric constant
In file included from e:\arduino ide\arduino-1.8.19-windows\arduino-1.8.19\libraries\hid_project-2.8.4\src\hid-apis\KeyboardAPI.h:29:0,
Multiple libraries were found for "Keyboard.h"
                 from e:\arduino ide\arduino-1.8.19-windows\arduino-1.8.19\libraries\hid_project-2.8.4\src\hid-apis\defaultkeyboardapi.h:27,
 Used: C:\Users\Lenovo\Documents\Arduino\libraries\Keyboard
 Not used: E:\Arduino IDE\arduino-1.8.19-windows\arduino-1.8.19\libraries\Keyboard
                 from E:\Arduino IDE\arduino-1.8.19-windows\arduino-1.8.19\libraries\HID_Project-2.8.4\src/SingleReport/BootKeyboard.h:30,
                 from E:\Arduino IDE\arduino-1.8.19-windows\arduino-1.8.19\libraries\HID_Project-2.8.4\src/HID-Project.h:50,
                 from C:\Users\Lenovo\Documents\Arduino\Rotary_Encoder_Multiplex\Rotary_Encoder_Multiplex.ino:2:
e:\arduino ide\arduino-1.8.19-windows\arduino-1.8.19\libraries\hid_project-2.8.4\src\keyboardlayouts\improvedkeylayouts.h:521:1: error: expected declaration before '}' token
exit status 1
How can I correct this??
It appears that you've included two different libraries that both want to provide keyboard support. And the compiler is complaining because they both want to define the same constants.
I would imagine the solution will begin with getting rid of the #include "Keyboard.h" line and figuring out how to do keyboard input with the HID library. But that's just a guess.
Thanks for the advice, will check it out
