HELP KEYPAD 4X4+MEGA 1280 PASSWORD
I NEED HELP
#include <Keypad.h>
char cmd;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
int c=0;
char password[5]={'3','1','3','1',''};
boolean password_flag=false;
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'1','2','3','a'},
{'4','5','6','b'},
{'7','8','9','c'},
','0','#','d'}
byte rowPins[ROWS] = { 24,25,22,23}; //connect to the row pinouts of the keypad
byte colPins[COLS] = { 28,29,26,27 }; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad cusomKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
char customKey = cusomKeypad.getKey();
void setup(){
cmd=Serial.read();
Serial.print("enter 2\n");
Serial.print(customKey);
void loop(){
if (customKey != NO_KEY){
if (customKey=='2')
Serial.print("enter pass\n");{
for(int i=0;i<5;i++)
if(customKey== password*)*
_ if(cmd==password*)_
_
c++;*_
* if(c==5)*
* password_flag=true;
if( password_flag==true)*
* Serial.print("all good\n");*
* else*
* Serial.print("eror");*
}}[/quote]
It does not refer to the following code segment
> _ c++;_
_
>_
> _ }_
> _ if(c==5)_
> password_flag=true;
_
>_
> _ Serial.print("all good\n");_
> _ }}}[/quote]*_
> ITS JUMP TO THE ELSE
I'm amazed that even compiles.
Shouldn't have the "{" at the end (also remove the corresponding "}")
I don't have an Arduino or IDE handy, so this may still be Full Of Bugs. Please note the questions, I think you need to look at your logic. Step through it manually line by line, because I'm fairly sure you'll never get this loop working like you want it to:
  if (customKey != NO_KEY) {
    if (customKey=='2') {  // What is this IF for? All it seems to do is to exclude any character that isn't "2", so your password will  never be matched.
        if(customKey == password) // Shouldn't this be password[i]? And don't you need to use strCmp()?
          if(cmd==password)  // Why are you doing this line? You are comparing both the serial input AND the stored password; if the serial + stored don't match, this will always be false
            c++;
      //  You need to reset variable c to zero if a wrong character is found otherwise typing 123*123*123*123*123* would match your 3131* password.
      if(c==5)
        password_flag=true;
The OP's code doesn't compile.
            if(customKey== password)
              if(cmd==password)
sketch_apr11a:52: error: ISO C++ forbids comparison between pointer and integer
sketch_apr11a:53: error: ISO C++ forbids comparison between pointer and integer
