HELP! - LCD scroll menu issue
Hello,
I am having trouble scrolling menu after going into a sub menu. The code works fine and the menu also scrolls when the buttons are pressed. But once i go to sub menu (like case 'A' or Case 'B'), and press * to get back to the home page the scrolling stops. All the functions work; I can still go to sub menu but cannot scroll down or up.
I would highly appreciate if you guys can help me out on this issue.
Regards,
#include <LiquidCrystal.h>
#include <Keypad.h>
int value=0;
int Cement_Weight = 0;
int Sand_Weight = 0;
int Water_Weight = 0;
char selection;
int page_counter=1 ;
int up = 52;
int down = 53;
boolean current_up = LOW;
boolean last_up=LOW;
boolean last_down = LOW;
boolean current_down = LOW;
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] =
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {14,15,16,17}; //row pinouts of the keypad (L1, L2, L3, L4)
byte colPins[COLS] = {18,19,20,21}; //column pinouts of the keypad (R1, R2, R3)
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
LiquidCrystal lcd1(2,3,4,5,6,7);
LiquidCrystal lcd2(2,9,4,5,6,7);
  lcd1.begin(20,4);
  lcd2.begin(20,4);
  lcd1.clear();
  lcd2.clear();
  Live_Weight_Display();
  keypad.addEventListener(keypadEvent);
boolean debounce(boolean last, int pin)
  boolean current = digitalRead(pin);
  if (last != current)
   delay(5);
  return current;
  char key = keypad.getKey();
  Scroll();
void Scroll()
  current_up = debounce(last_up, up);
  current_down = debounce(last_down, down);
//Page Up
  if (last_up== LOW && current_up == HIGH)
    lcd1.clear();                     //When page is changed, lcd clear to print new page
    if(page_counter <3)
    {              //Page counter never higher than 3(total of pages)
    page_counter= page_counter +1;   //Page up
     page_counter= 1;                //return to page 1
  last_up = current_up;
//Page Down
   if (last_down== LOW && current_down == HIGH)
     if(page_counter >1)
     {              //Page counter never lower than 1 (total of pages)
      page_counter= page_counter -1;   //Page down
     page_counter= 3;              //return to page 3
  last_down = current_down;
  switch (page_counter)
   case 1:
    menu();
   case 2:
   { //Design of page 3
     lcd1.setCursor(5,0);
     lcd1.print("This is");
     lcd1.setCursor(4,1);
     lcd1.print("Page 3");
   case 3:
   {   //Design of page 2
     lcd1.setCursor(1,0);
     lcd1.print("You are now on");
     lcd1.print("Page 2");
void Live_Weight_Display()
  lcd2.clear();
  lcd2.print("  Weight  Settings");
  lcd2.setCursor(0,1);
  lcd2.print("Cement  Sand  Water");
  lcd2.setCursor(0,2);
  lcd2.print(Cement_Weight);
  lcd2.print(" kg");
  lcd2.setCursor(8,2);
  lcd2.print(Sand_Weight);
  lcd2.print(" kg");
  lcd2.setCursor(14,2);
  lcd2.print(Water_Weight);
  lcd2.print(" kg");
void menu()
 lcd1.setCursor(0,0);
 lcd1.print("Menu: ");
 lcd1.setCursor(0,1);
 lcd1.print("For Cement Press A");
 lcd1.setCursor(0,2);
 lcd1.print("For Sand   Press B");
 lcd1.setCursor(0,3);
 lcd1.print("For Water  Press C");
void keypadEvent(KeypadEvent key)
 switch (key)
  case 'A':
      lcd1.clear();
      lcd1.print("Enter Cement Weight");
      lcd1.print("& Then Press #");
      lcd1.setCursor(5,2);
      lcd1.print("kg");
      Cement_Weight = getTheNumber();
  case 'B':
      lcd1.clear();
      lcd1.print("Enter Sand Weight");
      lcd1.print("kg");
      Sand_Weight = getTheNumber();
      Serial.print (Sand_Weight);
  case 'C':
      lcd1.clear();
      lcd1.print("Enter Water Weight");
      lcd1.print("kg");
      Water_Weight = getTheNumber();
  case 'D':
      lcd1.clear();
      lcd1.print("Cement:");
      lcd1.setCursor(7,0);
      lcd1.print(Cement_Weight);
      lcd1.print(" kg");
      lcd1.print("Sand  :");
      lcd1.setCursor(7,1);
      lcd1.print(Sand_Weight);
      lcd1.print(" kg");
      lcd1.print("Water :");
      lcd1.setCursor(7,2);
      lcd1.print(Water_Weight);
      lcd1.print(" kg");
      lcd1.print("Hold # to reset");
   case '*':
      lcd1.clear();
      page_counter= 1;
      loop();
 switch (keypad.getState())
  case HOLD:
      if (key == '#')
          Cement_Weight = 0;
          Sand_Weight = 0;
          Water_Weight = 0;
          lcd1.clear();
          lcd1.print(" kg");
          lcd1.print(" kg");
          lcd1.print(" kg");
int getTheNumber()
    char buffer[4];
    // Input up to 3 numbers until we find a * or #
    int i=0;
    while (1)
        // If it's a number AND we have space left, add to our string
        if ('0' <= key && key <= '9' && i < 3)
            buffer[i] = key;
            i++;
            Serial.print(key);
            lcd1.setCursor(i,2);
            lcd1.print(key);
        // If it's a * or #, end
        else if ('#' == key && i > 0)
            // Null terminate
            buffer[i] = 0;
            int value = atoi(buffer);  // Convert to an integer
            i = 0;
            return value;
