I have a piece of code. I am forcing the LED to turn of when serial input == 0. But besides that, I want the brightness to equeal the value that is being send over the serial communication. I have spend hours on this. Please help.
int ledPin = 10;
int brightness = 0;
pinMode(ledPin, OUTPUT);
int brightness = 0;
if (Serial.available())
brightness = Serial.read();
if (brightness == '0')
digitalWrite(ledPin, LOW);
digitalWrite(ledPin, brightness);
What's the format of your serial input data, and where's it coming from?
Before messing around with serial input, take a look at the [u]Fade Example[/u] and learn how to adjust the brightness under program control first. (Hint - You can't dim with a digital write or a digital output... unless you create your own PWM.)
Then, maybe try an experiment where you write-in a brightness value, assign it to a variable, and then use and Serial.print to make sure your variable has the value you expect, and that the variable is between 0 and 255 as required for PWM dimming.
When you combine those two functions, your program should work.
