Help!!!!!!! library file for OLED
Hello everyone
Im using a OLED display for my project. This is a local oled display, mono colour .I need library that suits it. So,i downloaded spark fun library . IS any library fine or the oled display should be of same company? Can anyone suggest ideal library file
The 'ideal' library file would be one that matches your display. Since we have no idea which display you are using we have no way of recommending a library.
Don
Yes, indeed, the controller and the size makes a lot of difference. Of course we even don't know whether the OP has an RGB or monochrome OLED.
Nevertheless, as author of u8g2 i will suggest u8g2 :wink:
Currently several people work hard to make u8g2 available for as much OLEDs as possible.
Oliver
How to call oled in program . I have installed this library , in my program I need to call the oled. For sparkfun library file it was microOled .
U8g2 comes with a lot of examples. Each example includes a lot of constructor lines for several different oleds. You have to uncomment your OLED there.
Of course we would be able to provide more precise advice, it we would know more about your OLED. Any link available for the microOLED?
Oliver
Ok, i guess you have to uncomment this line:
U8G2_SSD1306_64X48_ER_1_HW_I2C
Or, if your OLED is configured as SPI, then you have to use this constructor:
U8G2_SSD1306_64X48_ER_1_HW_SPI
Oliver
