[help] line follower
hei guys, i recently made a robot.(line follower) using: arduino uno, ardumoto,polu qrt8a (analog sensor), motors and batteries.
probably my error occurs in code...just one motor work, i don't know why. i tested both motors. they works, but not in this code.
here is my code..any suggestion?
#include <QTRSensors.h>
#define NUM_SENSORS   6     // number of sensors used
#define NUM_SAMPLES_PER_SENSOR  4  // average 4 analog samples per sensor reading
#define EMITTER_PIN   QTR_NO_EMITTER_PIN
QTRSensorsAnalog qtra((unsigned char[]) {0, 1, 2, 3, 4, 5},
  NUM_SENSORS, NUM_SAMPLES_PER_SENSOR, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
int PWMA = 3;
int PWMB = 11;
int max_speed = 200;
int proportional, Setpoint, integral, derivative, last_proportional, error_value, Kp, Ki, Kd, right_speed, left_speed;
double pozitie;
int MOTOR1_PIN1 = 12;
int MOTOR1_PIN2 = 3;
int MOTOR2_PIN1 = 13;
int MOTOR2_PIN2 = 11;
// int led = 13;
  Setpoint = 128;
  /* pid tuning parameters */
  Kp = 2.2; // 2.5
  Ki = 0.9; // 0.9
  Kd = 6;  // 6
    pinMode(MOTOR1_PIN1, OUTPUT);
  pinMode(MOTOR1_PIN2, OUTPUT);
  pinMode(MOTOR2_PIN1, OUTPUT);
  pinMode(MOTOR2_PIN2, OUTPUT);
  // pinMode(led, OUTPUT);
  pinMode(PWMA, OUTPUT);
  pinMode(PWMB, OUTPUT);
 // digitalWrite(led, HIGH);    // turn on Arduino's LED to indicate we are in calibration mode
  for (int i = 0; i < 400; i++)  // make the calibration take about 10 seconds
    qtra.calibrate();       // reads all sensors 10 times at 2500 us per read (i.e. ~25 ms per call)
 // digitalWrite(led, LOW);     // turn off Arduino's LED to indicate we are through with calibration
  // print the calibration minimum values measured when emitters were on
  for (int i = 0; i < NUM_SENSORS; i++)
    Serial.print(qtra.calibratedMinimumOn[i]);
    Serial.print(' ');
  // print the calibration maximum values measured when emitters were on
    Serial.print(qtra.calibratedMaximumOn[i]);
    Serial.print(' ');
  /*if (irrecv.decode(&results)) {
   switch (results.value)
   case 0x506A9BC7 :
   ir=0; //stop
   case 0xDBCB3A41 :
   ir=1; //start
   irrecv.resume(); // Receive the next value
  //if (ir) {
  digitalWrite(MOTOR1_PIN1, HIGH);
  digitalWrite(MOTOR1_PIN2, LOW);
  digitalWrite(MOTOR2_PIN1, LOW);
  digitalWrite(MOTOR2_PIN2, HIGH);
  pid_calc();
  calc_turn();
  motor_drive(right_speed, left_speed);
  /* else {
   digitalWrite(MOTOR1_PIN1, LOW);
   digitalWrite(MOTOR2_PIN2, LOW);
void pid_calc() {
  pozitie = qtra.readLine(sensorValues);
  pozitie = map(pozitie,0,5000,0,255);
  proportional = pozitie - Setpoint;
  integral = integral + proportional;
  derivative = proportional - last_proportional;
  last_proportional = proportional;
  error_value = int(proportional * Kp + integral * Ki + derivative * Kd);
void calc_turn() { //Restricting the error value between +256.
  if (error_value < -max_speed) {
    error_value = -max_speed;
  if (error_value > max_speed) {
    error_value = max_speed;
  // If error_value is less than zero calculate right turn speed values
  if (error_value < 0) {
    right_speed = max_speed + error_value;
    left_speed = max_speed;
  // If error_value is greater than zero calculate left turn values
  else {
    right_speed = max_speed;
    left_speed = max_speed - error_value;
void motor_drive(int right_speed, int left_speed) { // Drive motors according to the calculated values for a turn
  analogWrite(PWMA, right_speed);
  analogWrite(PWMB, left_speed);
Why haven't you got any debug prints in there?
i'm beginner in arduino...how i can do this?
Just like you printed the calibration results, but you print the values of variables at key points in your code
dude, i don't understand...after calibration i have:
28 27 30 22 22 18
227 634 797 666 786 699
and then...the robot are moving in circle..
Question: "Why is the robot moving around in circles?
Answer: "I don't know, let's ask the robot"
Start putting some debug prints into your code
   case 0x506A9BC7 :
   ir=0; //stop
  Serial.println (F("Stop"));
   case 0xDBCB3A41 :
   ir=1; //start
   Serial.println (F("Start"));
  //if (ir) {
. . .and so on.
