Help-Load Cell and displaying force meausred.
I'm working with force sensing project using a 300kg load cell , HX711 load cell amp, arduino and LCD display.
I got it running, I got the code form here
The scope for this project is to apply force to the load cell and record that value in the lcd dsiplay. As if you would apply a load to it and display the peak force.
I need help on figuring out what line of code i need to use. Or if I need to do something else.
I have very little experience in coding. But willing to research and get better at it.
I would just need a direction on where to go from here.
See the code below.
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
#define DT A0
#define SCK A1
#define sw 9
long sample=0;
float val=0;
long count=0;
unsigned long readCount(void)
  unsigned long Count;
  unsigned char i;
  pinMode(DT, OUTPUT);
  digitalWrite(DT,HIGH);
  digitalWrite(SCK,LOW);
  Count=0;
  pinMode(DT, INPUT);
  while(digitalRead(DT));
  for (i=0;i<24;i++)
    digitalWrite(SCK,HIGH);
    Count=Count<<1;
    if(digitalRead(DT))
    Count++;
  Count=Count^0x800000;
  return(Count);
  pinMode(SCK, OUTPUT);
  pinMode(sw, INPUT_PULLUP);
  lcd.begin(16, 2);
  lcd.print("    Weight ");
  lcd.setCursor(0,1);
  lcd.print(" Measurement ");
  lcd.clear();
  calibrate();
  count= readCount();
  int w=(((count-sample)/val)-2*((count-sample)/val));
  lcd.setCursor(0,0);
  lcd.print("Measured Weight");
  lcd.setCursor(0,1);
  lcd.print(w);
  lcd.print("g             ");
  if(digitalRead(sw)==0)
    val=0;
    sample=0;
    w=0;
    count=0;
    calibrate();
void calibrate()
    lcd.clear();
  lcd.print("Calibrating...");
  lcd.setCursor(0,1);
  lcd.print("Please Wait...");
  for(int i=0;i<100;i++)
    count=readCount();
    sample+=count;
  sample/=100;
  lcd.clear();
  lcd.print("Put 100g & wait");
  count=0;
  while(count<1000)
    count=readCount();
    count=sample-count;
  lcd.clear();
  lcd.print("Please Wait....");
  delay(2000);
    count=readCount();
    val+=sample-count;
  val=val/100.0;
  val=val/100.0;        // put here your calibrating weight
  lcd.clear();
Thanks!
I'm having a hard time figuring out what your requirements are, so I guess I can't help.
How about interest? Willingness to learn?
Maui is always nice.
