help making a nightlight please
Hello,
I picked up an arduino uno a couple days ago and could use some help with my project..
I basically need to have 3 groups of LEDs doing different things...
Group 1 and 2 are stars and a back lit horse I just need some white LEDs to stay lit all the time, this I have figured out as far as programming goes but Im not sure how to wire 20-30 LEDs with limited I/O pins.
Group 3 is for fireflies and I just need 4-6 yellow LEDs to fade in and out...
Programming it all I have covered but wiring it is throwing me off and im not sure where to start or what to look for...
I have: 5mm white LEDs 25mA 3.3 5mm Yellow LEDs 20-30mA 3.0v 74hc595 shift register x1
Thank you in advance for any help.
I have:
If you are going to get more LEDs, consider “neopixel” (from adafruit or others). A chain of them could be controlled by only one pin.
The LEDs that are on all the time don't have to be connected to I/O pins unless they'll be turned on & off by the Arduino.
If they do need to be controlled, they can all be controlled by one I/O pin, but they can't all be directly powered by one I/O pin. You'd need a transistor or MOSFET to boost the current.
The Arduino I/O pins are rated for 40mA maximum (about 2 LEDs maximum per pin) and a total I/O current of 200mA. (i.e. You can't get 40MA from all output pins at the same time without potential damage to the Arduino.)
You can use PWM to fade LEDs. Again if they all fade together, you can use one I/O pin and a transistor/MOSFET to boost the available drive current. If they need to be controlled/faded independently, each one needs it's own PWM output.
I don't think you need the shift register... With shift registers, 3 I/O pins can independently address/control an unlimited number of LEDs (you can daisy-chain shift registers) but you can't independently dim LEDs with a shift register.
...20 or 30 LEDs at an average of 25mA may be too bright for a night light. You may need to cut-down the current (by using higher-value current-limiting resistors).
DVDdoug: ...20 or 30 LEDs at an average of 25mA may be too bright for a night light. You may need to cut-down the current (by using higher-value current-limiting resistors).
the light from the 20-30 LEDs are only going to be visible through small holes so they wont be too bright... I may be able to get away with using less as long as the light is visible..
