Hi I am trying to make a small battery charger that also can test battery voltage value.
When you send test command the arduino cut the power from the external power source and test the battery activating a load and measuring the voltage from the battery at the begin and end of the test.
The volt command send the current charger voltage.
that part is working fine, but I want the arduino to send a serial command when the external power supply is down, but I can't make it
This is my code I try to comment it as good as possible
Please help me
int memory = 0; //Set memory to 0
const int Power_Pin = 3; // Pin used to detect power failure or not
int PowerState = 0; //Current power suply status
int lastPowerState = 0; //Last Power Supply state
pinMode(A1, INPUT); //Analog read of battery voltage
pinMode(2,OUTPUT); // Activate a relay with the test command
pinMode(3,INPUT); // Receive 5V from power source to detect Power Supply status
if (PowerState != lastPowerState) { //Detect changes in power supply
PowerState = digitalRead(Power_Pin); //reads power pin
if (PowerState == HIGH) { // It will be HIGH if there is power supply
Serial.println("Supply is back"); // Let you know when power is back
else {
Serial.println("No supply"); // Let you know that the power supply is off
delay(50);
lastPowerState = PowerState; //Record current power supply status
if (Serial.available() == 0) {} //wait for data available
String teststr = Serial.readString(); //read until timeout
teststr.trim(); // remove any \r \n whitespace at the end of the String
if (teststr == "volt") {
Serial.print("Corrent voltage is ") + Serial.print((analogRead(A1) * 0.0293255),1)+ Serial.println(" V");
if (teststr == "test") {
Serial.println("Starting 5s test");
digitalWrite(2, HIGH);
memory = analogRead(A1) * 0.0293255;
delay(4000);
Serial.print("Initial voltage is ") + Serial.print(memory,1)+ Serial.println(" V");
Serial.print("Current voltage is ") + Serial.print((analogRead(A1) * 0.0293255),1)+ Serial.println(" V");
digitalWrite(2, LOW);
You will have to move PowerState = digitalRead(Power_Pin); before the first if. As it's now, if (PowerState != lastPowerState) will always evaluate to false as both variables are set to 0 so you will never get inside the the 'if` body.
Please note that an Arduino that does not have power can not send anything Curious how you keep it alive long enough to send the message.
the code doesn't read the input pin unless there's a change in state
i don't see where the Relay is turned on except after a "test". shouldn't it be turned on in setup()?
i wonder if you may want to measure/report the voltage when external power is restored
may damage input pin if external power is > 5V. could drive an external transistor (and base resistor) that pulls down the digital pin used to monitor for it. what about simply measuring the voltage to determine when external power is available?
some other minor simplifications that hopefully make the code easier to understand
// battery charger monitor
const byte PinPower = 3; // Pin used to detect power failure or not
const byte PinRelay = 2; // relay
const byte PinAnalog = A1; // analog inpput
byte pwrLst;
enum { RelayOn = LOW, RelayOff = HIGH };
float
readVoltage (void)
return analogRead (A1) * 0.0293255;
void loop ()
// monitor external power
byte pwr = digitalRead (PinPower);
if (pwrLst != pwr) { //Detect changes in power supply
pwrLst = pwr;
if (pwr == HIGH)
Serial.println ("Supply is back");
Serial.println ("No supply");
delay (50);
return; // no input to process
String teststr = Serial.readString (); //read until timeout
teststr.trim (); // remove \r, \n, whitespace from end of the String
Serial.print ("Corrent voltage is ");
Serial.print (readVoltage());
Serial.println (" V");
Serial.println ("Starting 5s test");
digitalWrite (PinRelay, RelayOff);
delay (1000);
Serial.print ("Initial voltage is ");
delay (4000);
Serial.print ("Current voltage is ");
digitalWrite (PinRelay, RelayOn);
void setup () {
pinMode (A1, INPUT); // Analog read of battery voltage
pinMode (PinPower, INPUT); // sense external power
pinMode (PinRelay, OUTPUT);
Serial.begin (9600);
