HELP Matlab, Arduino, 3 servo
hello
I'm trying to control 3 servomotors from matlab via arduino. It is possible without a motor shield? And i saw that the motor shield (http://arduino.cc/en/Main/ArduinoMotorShield) suport only 2 servomotors... It is possible to control the servo from matlab via arduino without the motorshield?
yeah, you just need one digital pin per servo
if you are using 3 servos, make sure your using a external power source
It really depends on what you mean by "servomotor".
If you mean a common R/C servo, then yes, you only need a single pin to control the device.
If you don't mean an R/C servo, then you need to specify what device you have.
