HELP: Matrix Display on Conways
I am having alot of trouble with the conways example to display on matrix. I am using Arduino mega328 and 0018 ide. It all compiles after editing the FrequencyTimer2, but nothing happens when I upload it to the arduino. I feel It is all connected up correctly, but this is what I have:
 * Conway's "Life"
 * Adapted from the Life example
 * on the Processing.org site
 * Needs FrequencyTimer2 library
#include "FrequencyTimer2.h"
byte col = 0;
byte leds[8][8];
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[17]= {-1, 10, 12, 15, 17, 11, 14, 16, 3, 13, 5, 7, 9, 2, 4, 6, 8};
// col[xx] of leds = pin yy on led matrix
int cols[8] = {pins[5], pins[6], pins[7], pins[8], pins[9], pins[10], pins[11], pins[12]};
// row[xx] of leds = pin yy on led matrix
int rows[8] = {pins[1], pins[2], pins[3], pins[4], pins[13], pins[14], pins[15], pins[16]};
#define DELAY 0
#define SIZE 8
extern byte leds[SIZE][SIZE];
byte world[SIZE][SIZE][2];
long density = 50;
  setupLeds();
  randomSeed(analogRead(5));
  for (int i = 0; i < SIZE; i++) {
    for (int j = 0; j < SIZE; j++) {
      if (random(100) < density) {
        world[i][j][0] = 1;
      else {
        world[i][j][0] = 0;
      world[i][j][1] = 0;
  // Display current generation
      leds[i][j] = world[i][j][0];
  delay(DELAY);
  // Birth and death cycle
  for (int x = 0; x < SIZE; x++) {
    for (int y = 0; y < SIZE; y++) {
      // Default is for cell to stay the same
      world[x][y][1] = world[x][y][0];
      int count = neighbours(x, y);
      if (count == 3 && world[x][y][0] == 0) {
        // A new cell is born
        world[x][y][1] = 1;
      if ((count < 2 || count > 3) && world[x][y][0] == 1) {
        // Cell dies
        world[x][y][1] = 0;
  // Copy next generation into place
      world[x][y][0] = world[x][y][1];
int neighbours(int x, int y) {
 return world[(x + 1) % SIZE][y][0] +
         world[x][(y + 1) % SIZE][0] +
         world[(x + SIZE - 1) % SIZE][y][0] +
         world[x][(y + SIZE - 1) % SIZE][0] +
         world[(x + 1) % SIZE][(y + 1) % SIZE][0] +
         world[(x + SIZE - 1) % SIZE][(y + 1) % SIZE][0] +
         world[(x + SIZE - 1) % SIZE][(y + SIZE - 1) % SIZE][0] +
         world[(x + 1) % SIZE][(y + SIZE - 1) % SIZE][0];
void setupLeds() {
  // sets the pins as output
  for (int i = 1; i <= 16; i++) {
    pinMode(pins[i], OUTPUT);
  // set up cols and rows
  for (int i = 1; i <= 8; i++) {
    digitalWrite(cols[i - 1], LOW);
    digitalWrite(rows[i - 1], LOW);
  clearLeds();
  // Turn off toggling of pin 11 and 3
  FrequencyTimer2::disable();
  // Set refresh rate (interrupt timeout period)
  FrequencyTimer2::setPeriod(2000);
  // Set interrupt routine to be called
  FrequencyTimer2::setOnOverflow(display);
void clearLeds() {
  // Clear display array
  for (int i = 0; i < 8; i++) {
    for (int j = 0; j < 8; j++) {
      leds[i][j] = 0;
// Interrupt routine
void display() {
  digitalWrite(cols[col], LOW);  // Turn whole previous column off
  col++;
  if (col == 8) {
    col = 0;
  for (int row = 0; row < 8; row++) {
    if (leds[col][7 - row] == 1) {
      digitalWrite(rows[row], LOW);  // Turn on this led
    else {
      digitalWrite(rows[row], HIGH); // Turn off this led
  digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
Arduino digital pin 0 - no connection
Arduino digital pin 1 - no connection
Arduino digital pin 2 - LED matrix pin #21
Arduino digital pin 3 - LED matrix pin #8
Arduino digital pin 4 - LED matrix pin #22
Arduino digital pin 5 - LED matrix pin #10
Arduino digital pin 6- LED matrix pin #23
Arduino digital pin 7 - LED matrix pin #11
Arduino digital pin 8 - LED matrix pin #24
Arduino digital pin 9 - LED matrix pin #12
Arduino digital pin 10 - LED matrix pin #1
Arduino digital pin 11 - LED matrix pin #5
Arduino digital pin 12 - LED matrix pin #2
Arduino digital pin 13 - LED matrix pin #9
Arduino digital pin 14 - LED matrix pin #6
Arduino digital pin 15 - LED matrix pin #3
Arduino digital pin 16 - LED matrix pin #7
Arduino digital pin 17 - LED matrix pin #4
Arduino digital pin 18 - no connection
Arduino digital pin 19 - no connection
link to the data sheet for the LED matrix :
My feeling is that it is something to do with the code as nothing is working. Thanks for help!
Is anyone able to help me :D?
The data sheet and the list of connections you included in your first post show that you are good to go with the software and the wiring set for the green side of your dual color LEDs.
I am not experienced with the FrequencyTimer2 library. There is another thread with a similar problem at http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1273698465. Maybe you can use code from there if you are willing to change to the Timer1 library.
I have tried what you have said and swapped to timer1 asper the other topic, however still no output on matrix. This is so frustrating because i feel i have done everything right. On the Arduino now has the L light lit up and after about 60 seconds it comes up with random lights on at different places but that is after 60 seconds or so. Heres what I have used!
#include <TimerOne.h>
 * Conway's "Life"
byte analogPin = 5;
byte col = 0;
byte leds[8][8];
#define DELAY 0
#define SIZE 8
long density = 50;
 setupLeds();
 Timer1.initialize(100); // interrupt every 100 microseconds
 Timer1.attachInterrupt(display); // control will go to the display() function when the interrupt happens
       world[i][j][0] = 1;
     else {
       world[i][j][0] = 0;
     world[i][j][1] = 0;
 delay(DELAY);
       world[x][y][1] = 1;
       // Cell dies
       world[x][y][1] = 0;
void setupLeds() {
 clearLeds();
void clearLeds() {
     leds[i][j] = 0;
void display() {
 col++;
 if (col == 8) {
   col = 0;
   else {
 delayMicroseconds(900);  // Delay so that on times are longer than off time = brighter leds
Do you think I need to pin the matrix to the arduino as the default one that was used?, I don't think this should matter though?
