HI,
Basically, I want mount a accelerometer via magnet onto a motor, to monitor its vibration. I was hoping to get 600 readings from the accelerometer in each axis, so that I can do the FFT and analyse from there.
I did a dry run without mounting onto the motor, and I was able to get 600 readings without any problem. So I moved on to the real deal. I first set the RPM of the motor, waited for it to stabilize before mounting the sensor, however, I found myself getting readings of less than 300. And as the speed increases, the number of readings decreases as well!
Wondering if there is any problem in the program or the hardware. Maybe due to the magnet mounting? Or some technical knowledge that I am missing out.
I am using the ADXL345 for vibration trending.Accelerometer ADXL345
I am using the Arduino Uno R3 as a microcontroller. Arduino Uno Board R3
Logging data on the sd storage on the Arduino Wifi Shield.
#include <Wire.h>
#define DEVICE (0x53) //ADXL345 device address
#define TO_READ (6) //num of bytes we are going to read each time (two bytes for each axis)
#define THRESH_ACT (0x24)
#define THRESH_INACT (0x25)
#include <SPI.h>
#include <SD.h>
File myFile;
// Declare Variable
byte runComplete; //setting the number of iteration
int i; //delare i for count
byte buff[TO_READ];//6 bytes buffer for saving data read from the device
float voltage; //Analog input voltage from AD8495 thermocouple
float temp; //Temperature variable thermocoupple
float tem[10]; //Temperature variable thermocoupple
float x, y, z; //Acceleration variable
float x1, y1, z1; //Acceleration variable
// define Analog pin
float tpin = A0; //thermocouple to A0
void thermocouple() {
float voltage = analogRead(tpin); //Read voltage coming from AD8495
float vout = (voltage * 5)/ 1023.0; //Calculate vout
float temp = (vout - 1.25) / 0.005 ; //Convert to temperature
Serial.print("Thermocouple : "); Serial.print(temp); Serial.print((char)186); Serial.print(" C");Serial.println();
myFile = SD.open("temperature.txt", FILE_WRITE); // if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to Temperature.txt...");
myFile.println(temp);
myFile.close();// close the file:
Serial.println("done.");
Serial.println(F("error opening Tempearture.txt")) ;// if the file didn't open, print an error:
void writeTo(int device, byte address, byte val) {
Wire.beginTransmission(device); //start transmission to device
Wire.write(address); // send register address
Wire.write(val); // send value to write
Wire.endTransmission(); //end transmission
void readFrom(int device, byte address, int num, byte buff[]) { //reads num bytes starting from address register on device in to buff array
Wire.write(address); //sends address to read from
int n = Wire.requestFrom(device, num); // request 6 bytes from device
if( n == num)
Wire.readBytes(buff, n);
void regAddress()
int regAddress = 0x32; //first axis-acceleration-data register on the ADXL345
readFrom(DEVICE, regAddress, TO_READ, buff); //read the acceleration data from the ADXL345
//each axis reading comes in 10 bit resolution, ie 2 bytes. Least Significat Byte first!!
//thus we are converting both bytes in to one int
x = (((int)buff[1]) << 8) | buff[0];
y = (((int)buff[3])<< 8) | buff[2];
z = (((int)buff[5]) << 8) | buff[4];
x1 = (x/256)*9807;
y1 = (y/256)*9807;
z1 = (z/256)*9807;
Serial.println(" ");
Serial.print("X: ");Serial.print(x1); Serial.println(" mm/s2");
Serial.print("Y: ");Serial.print(y1); Serial.println(" mm/s2");
Serial.print("Z: ");Serial.print(z1); Serial.println(" mm/s2");
myFile = SD.open("x2.txt", FILE_WRITE); // if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to X.txt...");
myFile.println(x1);
Serial.println(F("error opening x.txt")) ;// if the file didn't open, print an error:
myFile = SD.open("y2.txt", FILE_WRITE); // if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to Y.txt...");
myFile.println(y1);
Serial.println(F("error opening Y.txt")) ; // if the file didn't open, print an error:
myFile = SD.open("z2.txt", FILE_WRITE);// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to Z.txt...");
myFile.println(z1);
Serial.println("");
Serial.println(F("error opening Z.txt")); // if the file didn't open, print an error:
Serial.println("");
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
writeTo(DEVICE, 0x2D, 0); //Turning on the ADXL345
writeTo(DEVICE, 0x2D, 16); //Turning on the ADXL345
writeTo(DEVICE, 0x2D, 8); //Turning on the ADXL345
writeTo(DEVICE, 0x31, 8);
Serial.println("Initializing Accelerometer...");
Serial.print("Initializing SD card...");
Serial.println("");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
Serial.println("");
return;
delay(2000);
if (runComplete == 0){
for (i=0; i<600; i=i+1){
Serial.print("Number of iteration(seconds) = "); Serial.print(i);
regAddress();
thermocouple();
delay(100);
runComplete = 1;
