here is the arduino code
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include "utility/debug.h"
#include "utility/socket.h"
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,SPI_CLOCK_DIVIDER);
#define WLAN_SSID "Hyzo"
#define WLAN_PASS "pass"
#define WLAN_SECURITY WLAN_SEC_WPA2
#define LISTEN_PORT 80
Adafruit_CC3000_Server httpServer(LISTEN_PORT);
int bufindex = 0;
cc3000.begin();
cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
delay(10000);
cc3000.checkDHCP();
httpServer.begin();
pinMode(8, OUTPUT);
Adafruit_CC3000_ClientRef client = httpServer.available();
byte kirim =(byte) client.read();
Serial.write(kirim);
if(kirim==1){digitalWrite(8,HIGH);}
else{digitalWrite(8,LOW);}
client.close();
and this is the mainactivity in java(android studio)
import android.app.Fragment;
import android.graphics.Color;
import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.TextView;
import java.net.*;
import java.io.*;
public class MainActivity extends ActionBarActivity {
private static TextView lamp, tvuser;
private static EditText user, pass;
private Socket sock;
private static String ipip = "192.160.10.103";
private static int portport = 80;
private static String response = "";
private static byte[] buffer = new byte[1024];
private static byte kirim=1;
private static InputStream in;
private static OutputStream out;
private static int stat;
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.content_main);
lamp = (TextView) findViewById(R.id.lamp);
try {
sock = new Socket(ipip, portport);
in= sock.getInputStream();
out = sock.getOutputStream();
// out.write(kirim);
stat = in.read(buffer);
}catch (Exception e){
public void onClick(View v){
switch (v.getId()){
case R.id.onon:
kirim = 1;
try{ out.write(kirim);}
catch (Exception e){}
try{ stat = in.read(buffer);}
if(stat == 1) {
lamp.setTextColor(Color.parseColor("#CCCC00"));
case R.id.offoff:
kirim=0;
if(stat == 0) {
lamp.setTextColor(Color.parseColor("#000000"));
2 side of program running, but they wont connect? why?
