help me connection failed
connection fail web hosting
http://www.autocontrol.in.th/Electical/user/status.php?user_home=boss
help me !!
#include <SPI.h>
#include <Ethernet.h>
// assign a MAC address for the ethernet controller.
// fill in your address here:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// fill in an available IP address on your network here,
// for manual configuration:
IPAddress ip(172,20,14,99);
// fill in your Domain Name Server address here:
IPAddress myDns(122,155,187,95);
// initialize the library instance:
EthernetClient client;
char server[] = "www.autocontrol.in.th";
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 1*1000;  // delay between updates, in milliseconds
boolean startRead = false;
int ledPins[] ={2, 3, 4, 5, 6, 7, 8, };
char buffer[16];
  // start serial port:
  // give the ethernet module time to boot up:
  // start the Ethernet connection using a fixed IP address and DNS server:
  Ethernet.begin(mac, ip, myDns);
  // print the Ethernet board/shield's IP address:
  Serial.print("My IP address: ");
  Serial.println(Ethernet.localIP());
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  if (client.available()) {
    dataReceived();
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
    Serial.println("disconnecting.");
    client.stop();
    startRead=false;
  // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    httpRequest();
  // store the state of the connection for next time through
  // the loop:
  lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void httpRequest() {
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    Serial.println("connecting...");
    // send the HTTP PUT request:
    //char url[64];
    //sprintf(url, "/test/status.php?device1=1&try=%u", lastConnectionTime);
    //sprintf(url, "GET %s HTTP/1.1", url);
    //Serial.print(url);
    startRead=false;
    client.println("GET /Electical/user/status.php?user_home=boss HTTP/1.1");
    //client.println("GET /test/status.php? HTTP/1.1");
    client.println("Host: www.autocontrol.in.th");
    client.println("User-Agent: arduino-ethernet");
    client.println("Connection: close");
    client.println();
    // note the time that the connection was made:
    lastConnectionTime = millis();
  else {
    // if you couldn't make a connection:
    Serial.println("connection failed");
    client.stop();
void dataReceived(){
     char c = client.read();
     if (c == '[' ) {
        startRead = true;
     }else if(startRead){
      static int buffer_idx=0;
      if ( c!=']' && buffer_idx < 15 ) {
        buffer[buffer_idx] = c;
        buffer_idx++;
        buffer[buffer_idx] = '\0';
        buffer_idx = 0;
        Serial.println(buffer);
        char * s1 = strtok(buffer, ",");
        doWork(1, s1);
        char * s2 = strtok(NULL, ",");
        doWork(2, s2);
        char * s3 = strtok(NULL, ",");
        doWork(3, s3);
        char * s4 = strtok(NULL, ",");
        doWork(4, s4);
        char * s5 = strtok(NULL, ",");
        doWork(5, s5);
        char * s6 = strtok(NULL, ",");
        doWork(6, s6);
        char * s7 = strtok(NULL, ",");
        doWork(7, s7);
        char* s8 = strtok(NULL, ",");
        doWork(8, s8);
void doWork(int index, char* val){
  int state=atoi(val);
  if(state==2) TurnOn(index);
  else if(state==1) TurnOff(index);
void TurnOn(int index){
  digitalWrite(ledPins[index], HIGH);
  Serial.print("LED ");
  Serial.print(index);
  Serial.println(" ON");
void TurnOff(int index){
  digitalWrite(ledPins[index], LOW);
  Serial.println(" OFF");
You have a rather strange setup with an IP address of 172.20.14.99 (private address range) but DNS services from 122.155.187.95 (public IP address, probably from your provider) but no gateway defined. How do you think does your Arduino reach the DNS server of your provider? If you have a standard setup with a router as your gateway to the internet, just ommit the DNS server and IP address parameters to Ethernet.begin() to have your Arduino use the DHCP protocol to get all needed parameters.
