I'm using an arduino nano. As a little test for a bigger project of mine, I've made a little program to interface an lcd and a couple of buttons. The polling of the buttons is handled by a function, which is called once for each button in the main loop. My issue is this: when I call the function to monitor just one switch, all goes well and my counter is incremented by one however long I keep the button pressed. However, when I call another instance of the same function to monitor a second button, the first one keeps triggering and increments the counter as long as the button is kept pressed, which is not the way it should behave. The serial monitor shows that, in this case, the button_flag variable continually oscillates between true and false, and, therefore, each true reading increments my counter. I've also tried to implement the same idea with return values from my polling function instead of pointers and and global variables, but the problem stays the same. Making a small library and implementing the polling function as a class seems overkill for such a trivial case. When I comment out the "crazy lane" (#49), all goes well. My code follows.
#include <LiquidCrystal.h>
const uint8_t rs = 12, en = 13, d4 = 8, d5 = 9, d6 = 10, d7 = 11;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// end LiquidCrystal
#define BUTTON_PIN 3
#define COUNTER_RESET_PIN 4
#define DEBOUNCE_DELAY 6
#define DEBUG 1
// Global varaibles
char gTimeString[9];
char gCounterString[9];
unsigned int gButtonCounter = 0;
bool gPushbutton, gReset;
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(COUNTER_RESET_PIN, INPUT_PULLUP);
#if DEBUG
#endif
// Lcd setup
lcd.begin(16,2);
delay(50);
lcd.clear();
delay(10);
// end setup
lcd.print("Uptime: ");
lcd.setCursor(0,1);
lcd.print("Counter: ");
updateTimeString((unsigned int) (millis() / 1000));
updateCounterString(gButtonCounter);
pollButton(BUTTON_PIN, &gPushbutton);
pollButton(COUNTER_RESET_PIN, &gReset); // <-- *** CRAZY LINE ***
if (gPushbutton)
gButtonCounter += 1;
#if DEBUG
Serial.println("Pushbutton = true.");
#endif
#if DEBUG
Serial.println("Pushbutton = false.");
#endif
} // end gPushbutton
if (gReset)
gButtonCounter = 0;
lcd.setCursor(8,0);
lcd.print(gTimeString);
lcd.setCursor(9,1);
lcd.print(gCounterString);
#if DEBUG
// slow down so we can follow it on monitor
delay (500);
#endif
void pollButton (int button_pin, bool * button_flag)
static bool last_state, current_state;
*button_flag = false;
current_state = digitalRead(button_pin);
if ( current_state != last_state )
delay(DEBOUNCE_DELAY);
if (current_state == 0) // active low
*button_flag = true;
} // end outer if
last_state = current_state;
return;
void updateTimeString (unsigned int seconds)
unsigned int h, m, s;
h = seconds / 3600;
m = (seconds / 60) % 60;
s = seconds % 60;
sprintf (gTimeString, "%02u:%02u:%02u", h, m, s);
gTimeString[8] = '\0';
return;
void updateCounterString (unsigned int number)
sprintf (gCounterString, "%7u", number);
return;
