Help me decode this Motor Controller- JMP BE-3714
Hi guys!
I found a motor controller that I'd like to use for to power my motor, and I need some help figuring out how to write code that would allow me to run it with an arduino.
The product name is JMP BE-3714. Here's a link to the product page (use google translate, its in chinese!) Or read the translated product description here (the tables are a little messy allow me to edit it a little later)
First, BE-3714 Features:
1, wide voltage input. The input voltage range is: 7V to 16.8V.
2, high current output. Single maximum output current can reach 10A.
3, acceleration, good controllability.
4, compatible with 3.3V / 5V signal level
5, support 6.7KHZ high frequency signal control
6, the module shape (LWH): 88mmX56mmX20mm
Second, the module shape
A
Power input port
Motor output port
Corresponding drive signal
B
Power supply output (RCU)
C1
Motor1
C
Motor output
C2
Motor2
D
Mounting hole (M3 screw)
C3
Motor2
E
S1 (short-acting module does not work)
C4
Motor3
F
Indicator light
C5
Motor3
G
Motor signal input
C6
Motor4
Third, the working parameters:
parameter name
Symbol
Minimum value
Typical value
The maximum value
unit
voltage
Vss
7
12.6
16.8 (Note 1)
V
Output current
Iss
10 (Note 2)
A
Signal input high voltage
Vih
3
5
5.3
V
Signal input low voltage
Vil
0
0
0.8
V
The output voltage
Vout
0
Vss
V
Note: (1) depending on the voltage at which the motor connected to the output can withstand
(2) refers to the power supply through the drive board on the load output current
Fourth, note:
1, the drive board for a long time do not use, to disconnect the power, otherwise it will consume power.
2, the power supply positive and negative do not reverse, otherwise it will burn the drive board.
3, the power supply voltage to the plug motor module is limited subject. Such as: motor rated voltage of 12V, the power supply can not exceed 12V, otherwise it will damage the motor.
Here are some pictures-
One thing I'm scratching my head over is that the arduino signal input (where I assume all the speed controls thru PWM and direction controls happen) has 6 pins. I understand there is black and red for ground and Vin. However, I have 0 clue with the 4 yellow wires. Why does this device need 4 signal specific pins? Any idea from the product page description?
Any help would be extremely appreciated!!
