Help me describing stop motors in the scope
#include <ESP32Servo.h> // Use the ESP32 compatible Servo library
// Motor A Pins
const int motor1Pin1 = 27; // IN1
const int motor1Pin2 = 26; // IN2
const int enable1Pin = 14; // ENA
// Motor B Pins (if needed)
const int motor2Pin1 = 33; // IN3
const int motor2Pin2 = 25; // IN4
const int enable2Pin = 32; // ENB
// Servo Pin
Servo myServo;
const int servoPin = 12;
// Ultrasonic Sensor Pins
const int trigPin = 13;
const int echoPin = 14;
// TZT Microphone Pin
const int micPin = 34;
// Distance threshold in cm
const int distanceThreshold = 20; // Adjust as needed
  // Motor Pins
  pinMode(motor1Pin1, OUTPUT);
  pinMode(motor1Pin2, OUTPUT);
  pinMode(enable1Pin, OUTPUT);
  pinMode(motor2Pin1, OUTPUT);
  pinMode(motor2Pin2, OUTPUT);
  pinMode(enable2Pin, OUTPUT);
  // Servo Setup
  myServo.attach(servoPin);
  // Ultrasonic Sensor Setup
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  // Microphone Setup
  pinMode(micPin, INPUT);
  // Read distance from ultrasonic sensor
  long distance = readUltrasonicDistance();
  // Check if the distance is below the threshold
  if (distance < distanceThreshold) {
    stopMotors(); // Stop all motors if too close
    Serial.println("Object too close! Stopping motors.");
    // Read microphone input and control motors based on commands
    int micValue = analogRead(micPin);
    processMicrophoneCommand(micValue);
  delay(100); // Short delay for stability
long readUltrasonicDistance() {
  long duration, distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration * 0.034) / 2; // Calculate distance in cm
  return distance;
void processMicrophoneCommand(int micValue) {
  // Simple command recognition based on micValue
  // You will need to adjust these thresholds based on your microphone's output
  if (micValue > 800) { // Example threshold for "move forward"
    moveForward();
    Serial.println("Moving Forward");
  } else if (micValue > 600) { // Example threshold for "move backward"
    moveBackward();
    Serial.println("Moving Backward");
  } else if (micValue > 400) { // Example threshold for "turn left"
    turnLeft();
    Serial.println("Turning Left");
  } else if (micValue > 200) { // Example threshold for "turn right"
    turnRight();
    Serial.println("Turning Right");
  } else { // If no command is recognized, stop
    stopMotors();
    Serial.println("Stopping Motors");
void moveForward() {
  digitalWrite(motor1Pin1, HIGH);
  digitalWrite(motor1Pin2, LOW);
  digitalWrite(motor2Pin1, HIGH);
  digitalWrite(motor2Pin2, LOW);
  analogWrite(enable1Pin, 255); // Full speed
  analogWrite(enable2Pin, 255); // Full speed
void moveBackward() {
  digitalWrite(motor1Pin1, LOW);
  digitalWrite(motor1Pin2, HIGH);
  digitalWrite(motor2Pin1, LOW);
  digitalWrite(motor2Pin2, HIGH);
void turnLeft() {
  void turnRight() {
I moved your topic to an appropriate forum category @idrisap .
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Can you please help , its actully urgent.
This is a group of volunteers, saying things like urgent or asap or hurry will only get you smart remarks.
This was fixed in your other post.
Please explain the problem. What did you expect the program to do, and what does it do instead?
i expected that the car will work on speech command, but codes are not getting upload and showing error
It might help us if you were to share the errors that are showing up…
a7
C:\Users\Admin\AppData\Local\Temp.arduinoIDE-unsaved2024114-964-1n149ks.1c4u\sketch_dec4a\sketch_dec4a.ino: In function 'void loop()':
C:\Users\Admin\AppData\Local\Temp.arduinoIDE-unsaved2024114-964-1n149ks.1c4u\sketch_dec4a\sketch_dec4a.ino:57:5: error: 'stopMotors' was not declared in this scope
57 | stopMotors(); // Stop all motors if too close
C:\Users\Admin\AppData\Local\Temp.arduinoIDE-unsaved2024114-964-1n149ks.1c4u\sketch_dec4a\sketch_dec4a.ino: In function 'void processMicrophoneCommand(int)':
C:\Users\Admin\AppData\Local\Temp.arduinoIDE-unsaved2024114-964-1n149ks.1c4u\sketch_dec4a\sketch_dec4a.ino:97:5: error: 'stopMotors' was not declared in this scope
97 | stopMotors();
exit status 1
Compilation error: 'stopMotors' was not declared in this scope
The compiler is correct (as usual). There is no function named stopMotors() in the code you posted.
ok thankyou everyone i got it
but after executing the code the car is not working not giving response
if any idea
Post the revised code in your next post, and clearly explain the new problem.
"Not working" is not a useful description of a problem.
revised codes
// Motor A Pins
// Servo Pin
Servo myServo;
  // Motor Pins
  // Servo Setup
  // Microphone Setup
  return distance;
    moveForward();
    moveBackward();
    turnLeft();
    turnRight();
    stopMotors();
void turnLeft() {
  void turnRight() {
 void stopMotors() {
  analogWrite(enable1Pin, 0); // Full speed
  analogWrite(enable2Pin, 0); // Full speed
after coding or after running the codes the should work or do any movement but my car is not showing any movement even after i give speech commands it is not showing any movement.what could be the reason any idea?
Ask ChatGPT, and STOP saying CODES, it's just CODE.
Does any output like this appear on the serial monitor?
Put in extra print statements like the one above, to see what is going wrong.
+1. Below is a draft I forgot about finiching, I see now that something should print if processMicrophoneCommand() gets called.
So it should print one way or the other, if not
then
Stopping Motors
Earlier:
Use printing. Maybe like
  Serial.print(" micValue = ");
  Serial.println(micValues);
You might need to play with your "speech recognition" module.
a7
