HELP ME!!! Desperation!
Hello arduino users! I am trying to get two servos to activate and respond to a knock sensor but CANNOT DO IT! I have scoured the web for code possibilities or anything of the sort but, clearly, have been unsuccessful. I am able to get both servos moving as I would like, but NEED them to only activate for a short time (3 seconds or so) by means of a knock sensor.
Any help in this matter would be greatly appreciated... this is for a group design project and we are all stumped!
THANKS!
Do you have any code written? If you can move a servo, just use this knock sensor code: http://www.arduino.cc/en/Tutorial/Knock but instead of changing the led state, move the servo.
OK- we have found that code and have been using it as a guide, yet we are confused about replacing the ledPin code with our servo code. Do you have any pointers?
Thank you!
Yes. Replace the line that toggles the led with the line to move the servo.
Ok- thank you again! We tried toggling our servo code:
#include <Servo.h>
Servo first; // create servo object
Servo second; // create servo object
int firstservopin = 8; // digital output to which signal wire(yellow) of first servo is connected
int secondservopin= 7; // digital output to which signal wire(yellow) of second servo is connected
first.attach(firstservopin); // attach the servo to digital output 8
second.attach(secondservopin); // attach the servo to digital output 7
first.write(90); // center the servo
second.write(90); // center the servo
first.write(0); // move first servo to pos 0
second.write(0); // move second servo to pos 0
first.write(120); // move first servo to pos 120
second.write(120); // move second servo to pos 120
With the example led knock sensor code, but we still have been unsuccessful after many attempts and are very frustrated! Everything is connected the way it should be, we still are unable to get the servos to respond to the knock sensor
Thank you
Have you gotten the knock sensor to work by itself? It's usually a good idea to get each component working before you start merging them.
If you're able, test your knock sensor to find your ideal threshold. This can be done by using a Serial.print(sensorReading); and watching the serial monitor in the Arduino IDE
Once you've established the threshold, it's time to merge all of the components. I would imagine it would look something like this:
#include <Servo.h>
//Servo
#define firstservopin 8
#define secondservopin 7
//Knock Sensor
#define knockSensor A0
const int threshold = 100; //Sensitivity of the Knock Sensor
int sensorReading;
  sensorReading = analogRead(knockSensor);
  if (sensorReading >= threshold) {
