Hello my name is Justin and I am new to the arduino world and I am hopelessly lost trying to write code to control my two brushless motors. I hope that you can help!? The servo library won’t work for my need. The code I need is kind of complicated. By the way I have a arduino micro that’s brand new. I need code that first sends a full pwm signal’s (2000-2200 microseconds) to both the esc’s for two seconds followed by lowest pwm signal (750-1000 microseconds or so) for five seconds. Here is where it gets complicated for me, I need one of the bldc/esc to go to between 40-45% throttle and stay there. I need the second bldc motor to be controlled 0-100% throttle by only a potentiometer. Here is where it gets even trickier (for me atleast…) I need the first motor/ESC that’s set at 40-45% to also be controlled by the potentiometer. So that for example when the potentiometer is turned 15% the first motor will be at 55-60% throttle and the second is at only 15% throttle. I know this is a large request but I really need help I’ve been trying for a week now after work trying different code combinations. Thanks for your help
#include <Servo.h>
Servo smmEDF; // create servo object to control a servo
Servo mmEDF; // twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
int potpin = 0;
int potpins = 1;
int val;
smmEDF.attach(9); // attaches the servo on pin 9 to the servo object
mmEDF.attach(10);
for(pos = 0; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
smmEDF.write(pos); // tell servo to go to position in variable 'pos'
delay(200); // waits 15ms for the servo to reach the position
mmEDF.write(pos);
delay(200);
for(pos = 180; pos>=0; pos-=1) // goes from 180 degrees to 0 degrees
mmEDF.write(pos);
delay(200);
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
mmEDF.write(val); // sets the servo position according to the scaled value
delay(15);
val = analogRead(potpins);
smmEDF.write(val);
delay(15);
Try the untested (but compiling) code below. You may need to adjust the max/min throttle values from the default 2000/1000 to arm the ESC’s.
#include <Servo.h>
#define potpin A0
int val;
mmEDF.attach(10);
// Do ESC's need calibrating every reboot?
smmEDF.writeMicroseconds(2000); // Full throttle (2300 max)
delay(2000); // Wait 2 seconds
smmEDF.writeMicroseconds(1000); // Min throttle (700 min)
delay(5000); // Wait 5 seconds
int val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 1000, 2000);// scale it to use it with the servo (value between 1000 and 2000)
mmEDF.writeMicroseconds(val); // sets the ESC speed according to the scaled value
val += 420; // Add 42% throttle constant
val = constrain(val, 1000, 2000); // Legalize result
smmEDF.writeMicroseconds(val); // sets the servo position according to the scaled value
delay(15);
