No screen on mine and hard coded disconnect/reconnect values. I have the code portion settled but I need guidance on any additional components I might need to use…
Do I need a current limiting resistor on the Arduino input? Anywhere else? It is an Adafruit Trinket Pro that accepts up to 16v so I’m just running it off the supply/input 12v power.
Any kind of capacitor anywhere for voltage smoothing?
I have the output connected to a 12v automative iso relay (100 ohm resistance) - If the Arduino is running and I disconnect the relay, the arduino resets; Why would that happen?
Also just looking for comments from the hive mind before I finalize this and solder it all to a real breadboard.
Fritzing diagrams are almost always misleading and often incomprehensible. Avoid them.
Yours is no exception: what "NPN"?
What are the pin assignments of the unknown "NPN"?
Voltage spike in the power line, because the relay is either not properly decoupled or lacks a flyback diode across the coil. You will eventually destroy the Arduino that way.
jremington:
So, you deliberately misled us by choosing "NPN" as the component.
An extremely bad idea.
You are wasting your own as well as our time.
Come on man, I am here to learn and ask questions. If I were the smartest person ever I wouldn't need to make a post and ask for commentary. I'm sorry I am wasting your time. You do not need to help if that is how you feel. I am here to learn. I am also bedridden so I'm trying to learn something new. Give me a break, no reason to be rude.
Added a flyback diode (1n4001)
Changed mosfet in diagram from NPN to PNP
Why is it an extremely bad idea to turn the mosfet off and on the way that I am?
