Help me find a interger overlow in the TLC 5940 library
TLC5940 is a 16 channel PWM chip. I am currently using the library: GitHub - PaulStoffregen/Tlc5940: 16 channel PWM LED driver based on the Texas Instruments TLC5940 chip.
There is a integer somewhere in this code such that the width 466 is the maximum you can set, and any number greater will cause an integer overflow and reset the angle values.
In example:
The code below will move to the upper limits. (all the way left then right)
// 1ms pulse is 204
#define SERVO_MIN_WIDTH 102
// 1.5 ms is 307
// 2ms pulse is 410
#define SERVO_MAX_WIDTH 466
//#define SERVO_MAX_WIDTH 467
#include <tlc_servos.h>
#include <Tlc5940.h>
int pinval = 0;
void setup(){ tlc_initServos();  }
void loop(){
tlc_setServo(pinval, 0);
Tlc.update();
delay(2000)
tlc_setServo(pinval, 180);
Tlc.update();
delay(2000);
The code below will move to one direction and stay there.
// 1ms pulse is 204
// 1.5 ms is 307
// 2ms pulse is 410
//#define SERVO_MAX_WIDTH 466
int pinval = 0;
void loop(){
Tlc.update();
delay(2000)
Tlc.update();
delay(2000);
also there 2 codes are functionally equivalent:
// 1ms pulse is 204
// 1.5 ms is 307
// 2ms pulse is 410
#define SERVO_MAX_WIDTH 466+ 307 - 102
//#define SERVO_MAX_WIDTH 307
int pinval = 0;
void loop(){
Tlc.update();
delay(2000);
Tlc.update();
delay(2000);
// 1ms pulse is 204
// 1.5 ms is 307
// 2ms pulse is 410
//#define SERVO_MAX_WIDTH 466+ 307 - 102
int pinval = 0;
void loop(){
Tlc.update();
delay(2000);
Tlc.update();
delay(2000);
Help me out.
Doing this is calling for trouble
Imagine someone writing this code X = 2 * SERVO_MAX_WIDTH;You would expect the answer to be 2 * 671 thus 1342
But the pee processor replaces the #define textually so you get X = 2 * 466+ 307 - 102;and with operator precedence you only multiply by 2 the 466 and not the full thing...
Makes sense?
I hate define.
Instead of this:
use this:
const int SERVO_MAX_WIDTH = 466+ 307 - 102;
or even
const int SERVO_MAX_WIDTH = 671; // I did the math
Even if const takes up a lousy two bytes more of RAM than define, it is worth it for the peace of mind. And depending on what the compiler does, it might not even take up that much.
