Help me finding this component
Hi all,
i`ve just finished my new pcb but i cannot find this connector on the market!
I can buy stuff unfortunately only from RS and FARNELL.
The component i`m looking for is that one:
http://store.arduino.cc/it/index.php?main_page=product_info&cPath=6&products_id=188
i would need all the set, for an Arduino DUE/MEGA shield
Thanks!
Hi, search for " header pins " in RS or Farnell E14, that should give you a selection of 1/10th inch, 2.54mm spaced pins.
Tom
Thanks fot the hint! Now i`ll look for it.
While, could you also help me finding the connector for the ICSP/SPI (my shield will be sandwitched between the DUE and the Ethernet shield) ?
Something like this?
For Farnell go to Wire-to-Board http://uk.farnell.com/wire-to-board and select the following filters
Gender: Receptacle
No. of Rows: 1
Pitch Spacing: 2.54mm
Contact Termination: Through Hole Vertical
Hope that helps
