I recently bought a used mobility scooter but didn't last too long. Brushes were gone. I bought a damaged hoverboard and planning on using the motors, but don't have any controllers. I made a schematic but i can't find any software that will work with my setup. Can you please help me?
Here's the schematic i've made from a couple other schematics:
I just want it to drive the motors properly, and a must have is the reverse function since i can't...get off the scooter and turn it myself. I need them to be as powerful as they can be since there's alot of hills where i live. I bought some Chinese controllers and they all disappointed me, that's why i'm looking to build it myself..
The controller was a chinese one, THIS ONE. But drived the motors quite hard, with no PWM and the original hoverboard battery got hot, motors got hot too. And waaay to noisy. Took the original driver out and replaced it with arduino nano. And this is where things got complicated.
This is how it looks for now:
LM317 is missing because it fried at 38V and replaced it with a shunt, now making all the testing on 12V
Oh, sorry, english is not my native language. I want to use a simple HALL acceleration to input the speed/power and i want to reverse by activating a switch.
You have mobility differences and live somewhere with lots of hills? Ok, don't do this with Arduino. That's my suggestion. If the problem is with the motor brushes in the scooter, replace the motors in the scooter. Maybe the batteries, too, if they're older. The reverse control on these is often just a little paddle by the handlebars, isn't it?
Point is, if your car has an engine problem, you don't replace the whole ECU. You fix the engine. This is where you should begin. Bit of tough love and I don't mind being the one to say it: looking at your work so far, the plan you're proposing here is going to get you hurt in an accident or at best, stranded. There are certain projects that Arduino ought not do: powered wheelchairs/scooters for people with mobility differences fall squarely into that category. What if it gets wet? How are you protecting the controller from back-EMF and how are you securing the components into something that will be vibrating all the time as you use it?
You're going to spend a lot more time and money on the Arduino solution you're hoping for, than you would just fixing the scooter. Sorry to be so blunt and pessimistic, but as someone whose brother relied on mobility devices for 26 years before he passed away, this is my opinion and you should save the Arduino for another project. Maybe an automatic LED controller to supe up your ride or a battery voltage monitor?
I don't understand this whole thread! Electric motor brushes are one thing that is replaced as a normal part of life. All motor brushes wear out and are made to be replaced.
As I said before, better to just fix the scooter. However, not to come off as ableist, here you go:
/* BLDC Hall Sensor read and calculation program for Teensy 3.5 in the Arduino IDE (Ver.1). Digi-Key Electronics*/
/***************************** Variables *********************************/
#define CW 1 // Assign a value to represent clock wise rotation
#define CCW -1 // Assign a value to represent counter-clock wise rotation
bool HSU_Val = digitalRead(2); // Set the U sensor value as boolean and read initial state
bool HSV_Val = digitalRead(3); // Set the V sensor value as boolean and read initial state
bool HSW_Val = digitalRead(4); // Set the W sensor value as boolean and read initial state
int direct = 1; // Integer variable to store BLDC rotation direction
int pulseCount; // Integer variable to store the pulse count
float startTime; // Float variable to store the start time of the current interrupt
float prevTime; // Float variable to store the start time of the previous interrupt
float pulseTimeW; // Float variable to store the elapsed time between interrupts for hall sensor W
float pulseTimeU; // Float variable to store the elapsed time between interrupts for hall sensor U
float pulseTimeV; // Float variable to store the elapsed time between interrupts for hall sensor V
float AvPulseTime; // Float variable to store the average elapsed time between all interrupts
float PPM; // Float variable to store calculated pulses per minute
float RPM; // Float variable to store calculated revolutions per minute
/***************************** Setup *********************************/
// Set digital pins 2, 3 and 4 as inputs
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
// Set digital pins 2, 3 and 4 as interrupts that trigger on rising and falling edge changes. Call a function (i.e. HallSensorU) on change
attachInterrupt(digitalPinToInterrupt(2), HallSensorU, CHANGE);
attachInterrupt(digitalPinToInterrupt(3), HallSensorV, CHANGE);
attachInterrupt(digitalPinToInterrupt(4), HallSensorW, CHANGE);
// Initialize the print monitor and set baud rate to 9600
/*************************** Main Loop ******************************/
if ((millis() - prevTime) > 600) RPM = 0; // Zero out RPM variable if wheel is stopped
//Serial.print(HSU_Val); Serial.print(HSV_Val); Serial.println(HSW_Val); // Display Hall Sensor Values
//Serial.println(direct); // Display direction of rotation
//Serial.println(pulseCount); // Display the pulse count
Serial.println(RPM); // Display revolutions per minute
/************************ Interrupt Functions ***************************/
void HallSensorW()
startTime = millis(); // Set startTime to current microcontroller elapsed time value
HSW_Val = digitalRead(4); // Read the current W hall sensor value
HSV_Val = digitalRead(3); // Read the current V (or U) hall sensor value
direct = (HSW_Val == HSV_Val) ? CW : CCW; // Determine rotation direction (ternary if statement)
pulseCount = pulseCount + (1 * direct); // Add 1 to the pulse count
pulseTimeW = startTime - prevTime; // Calculate the current time between pulses
AvPulseTime = ((pulseTimeW + pulseTimeU + pulseTimeV)/3); // Calculate the average time time between pulses
PPM = (1000 / AvPulseTime) * 60; // Calculate the pulses per min (1000 millis in 1 second)
RPM = PPM / 90; // Calculate revs per minute based on 90 pulses per rev
prevTime = startTime; // Remember the start time for the next interrupt
void HallSensorV()
HSU_Val = digitalRead(2); // Read the current U (or W) hall sensor value
direct = (HSV_Val == HSU_Val) ? CW : CCW;
pulseTimeV = startTime - prevTime;
RPM = PPM / 90;
void HallSensorU()
HSW_Val = digitalRead(4); // Read the current W (or V) hall sensor value
direct = (HSU_Val == HSW_Val) ? CW : CCW;
pulseTimeU = startTime - prevTime;
RPM = PPM / 90;
taken from
[https://www.digikey.ca/en/blog/using-bldc-hall-sensors-as-position-encoders-part-3](https://www.digikey.ca/en/blog/using-bldc-hall-sensors-as-position-encoders-part-3)
type or paste code here
