if (count>0 && sensorState1 == LOW){ toupon();} //turns ON light from 1st to last step
if (count>0 && sensorState4 == LOW){ todownon();} //Turns On light from last to 1st step
if i use this in above code..it works for every count in loop.. like 1 or 2 or 3 etc it just does all the thinks in the void toupon(); or todownon(); all again
soo i changed to this way
if (count=0 && sensorState1 == LOW){ toupon();}
if (count=0 && sensorState4 == LOW){ todownon();}
but the problem here is ..it just not count more than 1 ...just loops 1 every time its triggered
my motive is turn on lights only when count one is triggered and after that it just do the count job and not repeat the same lights funtion as already lights are turned on. help me fix this
full code
#include <ShiftRegister74HC595.h>
// create a global shift register object
// parameters: <number of shift registers> (data pin, clock pin, latch pin)
ShiftRegister74HC595<2> sr(14, 16, 15);
#define sensorPin1 5 //ir sensor 1
#define sensorPin2 7 //ir sensor 2
#define sensorPin3 9 //ir sensor 3
#define sensorPin4 11 //ir sensor 4
int sensorState1 = 0;
int sensorState2 = 0;
int sensorState3 = 0;
int sensorState4 = 0;
int count=0;
int time1=100;
void toupon() { //Turn on 1st to last light
for(int i=0;i<16;i++) {
sr.set(i, HIGH);
delay(time1);
Serial.print("turn on light");
Serial.println(i);
void toupoff() { //Turn off from 1st to last light
sr.set(i, LOW);
delay(time1);
Serial.print("turn off light ");
Serial.println(i);
void todownon() { //turn on last to first light
for(int i = 15; i>=0; i--) {
sr.set(i, HIGH);
delay(time1);
Serial.print("turn on light ");
Serial.println(i);
void todownoff() { //turn off last to first light
sr.set(i, LOW);
delay(time1);
Serial.println(i);
Serial.println("FUN Started");
Serial.print(count);
pinMode (sensorPin1,INPUT);
pinMode (sensorPin2, INPUT);
pinMode (sensorPin3,INPUT);
pinMode (sensorPin4,INPUT);
int timex=800;
sensorState1 = digitalRead(sensorPin1);
sensorState2 = digitalRead(sensorPin2);
sensorState3 = digitalRead(sensorPin3);
sensorState4 = digitalRead(sensorPin4);
int lower = digitalRead(sensorPin1);
int upper = digitalRead(sensorPin4);
if (count < 0)
count = 0;
if(sensorState1 == LOW || sensorState4 == LOW ){ //counts people IN
count++;
Serial.println(count);
delay(timex);
if(sensorState2 == LOW || sensorState3 == LOW ){ //counts people OUT
count--;
delay(timex);
if(count<=0 && sensorState2 == LOW)
todownoff();
if(count<=0 && sensorState3 == LOW)
toupoff();
toupon();
todownon();
