Help me for an Arduino code error
Hi, I want to create code for an Arduino Project, but the Arduino software finds error and I can't understand it. Can you help me? Here is the code:
int relay = 13;
int i;
pinMode(relay, OUTPUT);
for(i = 0, i < 100; i++){
digitalWrite(relay, HIGH);
delay(300);
digitalWrite(relay, LOW);
delay(300);
delay(5000);
It says: Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Users\bobom\Desktop\Arduino\ReadyCodes\Ignition\Ignition.ino: In function 'void loop()':
Ignition:12:24: error: expected ';' before ')' token
exit status 1
And it marks the "For Loop" line.
You have used a comma in your for loop, but the compiler expects a semi-colon.
Like this:
int relay = 13;
int i;
for(i = 0; i < 100; i++;){
delay(300);
delay(300);
delay(5000);
One too many ; in your for loop, and not enough code tags
I cant understand you
Too many semicolons.
I don't really know how to make it simpler.
I need to use semicolons for the code to work
Yes you do.
But you have too many.
ok. can you tell me witch one to remove
Hello
Take some time and learn the basics of C.
Hi @b0b4u
Your line:
correct line.
for(i = 0; i < 100; i++){
RV mineirin
