Help me For THESIS PURPOSES
How to post the readings from the sensors to the API because it returns http code 400
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
const char* ssid = "";
const char* password = "";
//Your Domain name with URL path or IP address with path
const char* serverName = "";
const byte interruptPin = 4;
const int interval = 500;
volatile unsigned long tiptime = micros();
static float rainrate;
//float totalrainrate = 0.3;
void ICACHE_RAM_ATTR count();
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 5 seconds (5000)
unsigned long timerDelay = 15000;
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  Serial.println("Timer set to 5 seconds (timerDelay variable), it will take 5 seconds before publishing the first reading.");
    // Set up our digital pin as an interrupt
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), count, RISING);
  wifi();
  rain();
void rain() {
unsigned long curtime = micros();
  // Make sure we don't record bounces
  if ((curtime - tiptime) < interval) {
    return;
  // How long since the last tip?
  unsigned long tipcount = curtime - tiptime;
  tiptime = curtime;
  // Calculate mm/hr from period between cup tips
 Serial.print("Rain rate: ");
 Serial.print((float) rainrate * 0.1);
 //Serial.println("mm/hr");
 delay (1000);
void count() {
  rainrate++;
void wifi() {
  //Send an HTTP POST request every 10 minutes
  if ((millis() - lastTime) > timerDelay) {
    //Check WiFi connection status
    if(WiFi.status()== WL_CONNECTED){
      HTTPClient http;
      // Your Domain name with URL path or IP address with path
      http.begin(serverName);
      // Specify content-type header
      http.addHeader("Content-Type", "application/json");
      // Data to send with HTTP POST
      int httpResponseCode = http.POST( "{\"amount\":  \" rainrate\"  }" );
      Serial.print("HTTP Response code: ");
      Serial.println(httpResponseCode);
      // Free resources
      http.end();
    else {
      Serial.println("WiFi Disconnected");
    lastTime = millis();
What do you think the error of this code ?
thesispurposes:
What do you think about the 'error' that you have kept secret ?
You are incrementing rainrate in your interrupt. You need to use the volatile keyword when declaring rainrate. Also, since rainrate is a multibyte variable, you need to disable interrupts when you manipulate it outside of an interrupt, otherwise you will get corrupted values.
I'm not sure about the http code 400 but I would suggest verifying the rest of the code using the serial console before trying to send it in http.
 int httpResponseCode = http.POST( "{\"amount\" rainrate }" );
I think this is where the problem is comming from what do you think? is my JSON format is correct ?
Have you tried running some simple example sketches to confirm that you have basic connectivity to the server?
int httpResponseCode = http.POST( "{\"amount\" \"15\"}" );
yes if i replace it to sample data it successfully POST a request
Oh, yeah. Strings inside "" are constants ("character string literals") in C. You can't just throw in a variable. You have to use some conversion function to express the float variable as a character string.
What kind of variable can i use ? im only beginer
@thesispurposes
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
