help me generate a 3 phase output
hai guys help me in generating a 3phase supply! i can use set up a 6 pulse inverter! all i need a 6 gate pulse to produce the 3phase wave! help me with a code!and explain too! also i should be able to change the frequency by using a pot! no extra buttons!
If you could give some details, maybe someone can give you useful advice.
What will the
3 phase output
drive? Give a URL if possible.
What equipment do you have?
Do you have a description of your over all plan?
Do you have a sketch made yet (working or not )?
Hi, try this for some info on using PWM and output devices for 3 phase drive.
http://myelectrical.com/notes/entryid/152/variable-frequency-drive
Also google danfoss vsd theory , they have a lot of info on how their drives operate.
Tom.
http://forum.arduino.cc/index.php?topic=183481.msg1383439#msg1383439
Use gate drive chips with complementary outputs, then you only need 3 PWM pulse trains
Space vector modulation is the way to go but its not suited to 8 bit uC, I think it could possibly be done by a very smart programmer on an 8 bit uC as in the past (back in the day!) people like Thomas Lipo did manage it but they were coding in assembly
I have looked in the past (briefly) to see if anyone has done a three phase SVM algorithm to run off an 8 bit AVR but I have yet to see one
Which means you are best advised to use a 32 bit uC from the off that will make your life so much easier
arunmag:
If you're hoping that somebody will give you the code, you should be asking in the Gigs and Collaborations section. Note that most people would expect to be paid for doing work for you.
If you plan to write the code yourself and want help with specific problems you encounter while doing that, you could ask for help in the programming section. However, people will still expect you to write the code yourself and are only offering advice - not writing it for you.
