HELP ME GIVE LATEST VERSION FOR CODE IRrecvDumpV2.ino TO DETECT SIGNAL DATA
Please help me give code latest version IRrecvDumpV2.ino, i have problem my serial monitor running without press any button on AC Remote. someone say my library IRremote.h not up to date that why IRrecvDumpV2.ino have problem get signal data remote. Please help me i only need signal data remote AC ON,OFF, Temperature 23,24,25,26,27,28,29,30. help me with give IRrecvDumpV2.ino latest version code and give what library i need for IRrecvDumpV2.ino. I appreciate if anyone can help me. im using ardunio mega 2560
Use the Arduino IDE Library Manager to update the library:
already latest version my IRremote.h. maybe the problem is IRrecvDumpV2.ino code. my ardunio dont have IRrecvDumpV2 and i need manually put file IRrecvDumpV2 but always have error but still done complie.
// Include the IRremote library header
#include <IRremote.h>
// Tell IRremote which Arduino pin is connected to the IR Receiver (TSOP4838)
int recvPin = 11;
IRrecv irrecv(recvPin);
// Configure the Arduino
void  setup ( )
  Serial.begin(9600);   // Status message will be sent to PC at 9600 baud
  irrecv.enableIRIn();  // Start the receiver
// Display IR code
void  ircode (decode_results *results)
  // Panasonic has an Address
  if (results->decode_type == PANASONIC) {
    Serial.print(results->address, HEX);
    Serial.print(":");
  // Print Code
  Serial.print(results->value, HEX);
// Display encoding type
void  encoding (decode_results *results)
  switch (results->decode_type) {
    default:
    case UNKNOWN:      Serial.print("UNKNOWN");       break ;
    case NEC:          Serial.print("NEC");           break ;
    case SONY:         Serial.print("SONY");          break ;
    case RC5:          Serial.print("RC5");           break ;
    case RC6:          Serial.print("RC6");           break ;
    case DISH:         Serial.print("DISH");          break ;
    case SHARP:        Serial.print("SHARP");         break ;
    case JVC:          Serial.print("JVC");           break ;
    case SAMSUNG:      Serial.print("SAMSUNG");       break ;
    case LG:           Serial.print("LG");            break ;
    case WHYNTER:      Serial.print("WHYNTER");       break ;
    case PANASONIC:    Serial.print("PANASONIC");     break ;
    case DENON:        Serial.print("Denon");         break ;
// Dump out the decode_results structure.
void  dumpInfo (decode_results *results)
  // Check if the buffer overflowed
  if (results->overflow) {
    Serial.println("IR code too long. Edit IRremoteInt.h and increase RAWLEN");
    return;
  // Show Encoding standard
  Serial.print("Encoding  : ");
  encoding(results);
  Serial.println("");
  // Show Code & length
  Serial.print("Code      : ");
  ircode(results);
  Serial.print(" (");
  Serial.print(results->bits, DEC);
  Serial.println(" bits)");
void  dumpRaw (decode_results *results)
  // Print Raw data
  Serial.print("Timing[");
  Serial.print(results->rawlen-1, DEC);
  Serial.println("]: ");
  for (int i = 1;  i < results->rawlen;  i++) {
    unsigned long  x = results->rawbuf[i] * USECPERTICK;
    if (!(i & 1)) {  // even
      Serial.print("-");
      if (x < 1000)  Serial.print(" ") ;
      if (x < 100)   Serial.print(" ") ;
      Serial.print(x, DEC);
    } else {  // odd
      Serial.print("     ");
      Serial.print("+");
      if (i < results->rawlen-1) Serial.print(", "); //',' not needed for last one
    if (!(i % 8))  Serial.println("");
  Serial.println("");                    // Newline
void  dumpCode (decode_results *results)
  // Start declaration
  Serial.print("unsigned int  ");          // variable type
  Serial.print("rawData[");                // array name
  Serial.print(results->rawlen - 1, DEC);  // array size
  Serial.print("] = {");                   // Start declaration
  // Dump data
    Serial.print(results->rawbuf[i] * USECPERTICK, DEC);
    if ( i < results->rawlen-1 ) Serial.print(","); // ',' not needed on last one
    if (!(i & 1))  Serial.print(" ");
  // End declaration
  Serial.print("};");  //
  // Comment
  Serial.print("  // ");
  encoding(results);
  Serial.print(" ");
  ircode(results);
  // Newline
  Serial.println("");
  // Now dump "known" codes
  if (results->decode_type != UNKNOWN) {
    // Some protocols have an address
      Serial.print("unsigned int  addr = 0x");
      Serial.println(";");
    // All protocols have data
    Serial.print("unsigned int  data = 0x");
// The repeating section of the code
void  loop ( )
  decode_results  results;        // Somewhere to store the results
  if (IrReceiver.decode()) {  // Grab an IR code
    dumpInfo(&results);           // Output the results
    dumpRaw(&results);            // Output the results in RAW format
    dumpCode(&results);           // Output the results as source code
    Serial.println("");           // Blank line between entries
    irrecv.resume();              // Prepare for the next value
im new to arduino please give me latest IRrecvDumpV2.ino
this code i already change
i get error if not change this
  if (irrecv.decode(&results)) {  // Grab an IR code
my ardunio version 1.8.16
Some of the library examples have changed. Try: File->Examples->IRremote->ReceiveDump
@peace_minusone
this name seems to be program
do something that removes the "minusone" to achieve inner peace again.
And then post without using captial letters in the titel.
CAPTIAL LETTERS in the title gives the impression that you want to say "hurry up and post working code for me!!!"
The effect is the opposite of what you want.
best regards Stefan
If you took IRrecvDumpV2.ino from the following lib, then it only works on ESP8266/ESP32. This lib has lots of support for air cond IR codes.
