help me. how to change delay on pir sensor.?
anyone can help me ?
how to change delay on my script.
delay pir sensor always crash with ldr sensor.
how to make sensors running simultaneously without waiting delay completion
helpme.ino (1.99 KB)
//------------alternative to change delay?-----
//--------------- variabel  ldr-------------------
const int Pinled = 8;
int valueLDR;
//--------------- variabel  pir-------------------
int ledpir  = 13;
const int ReadPir  = 2;
unsigned long turnoff; // time to turn off pir led
  //SET PIN (OUTPUT/INPUT)
  //------------------LDR
  pinMode(Pinled, OUTPUT); // Set pin 8 -> output led from LDR sensor
  pinMode(A0, INPUT); // Set pin A0 -> input [pir]
  //------------------PIR
  pinMode(ledpir, OUTPUT); //------ [led]set pin output for [pir]
  pinMode(ReadPir, INPUT); //------ set pin INPUT  for [pir]
  valueLDR = analogRead(A0);
  if (valueLDR < 100)
    digitalWrite(Pinled, HIGH);
    digitalWrite(Pinled, LOW);
  if (digitalRead(ReadPir) == HIGH)
    digitalWrite(ledpir, HIGH);
    turnoff = millis() + 10000; // turn it off in ten seconds
  if (millis() > turnoff)   digitalWrite(ledpir, LOW);
thank you .
it's work.
