Help me improve my dire first attempt at soldering
Oscar_Zeta_Acosta:
Thanks for the help guys. So, I won't get away with leaving it as it is?
I have some desilder braid but I struggle to get the molten solder to soak into it.
You can probably get away with leaving it the way it is. I did not see any places where the solder bridged the gap between pins. The main problem with your soldering job is that you wasted solder. But practice makes perfect. Or at least practice makes you better. So I would just try to improve next time.
I'm surprised that you are having trouble with the desoldering braid. That stuff usually works pretty well.
Just put the braid on top of the solder you want to remove and press down on the braid with the tip of your soldering iron. Make sure you press down firmly, or the heat will not make it through the braid to melt the solder. And be sure to move to a new spot on the braid when the old spot has turned silver with solder.
