HELP ME IN MY PROJECT ..
417/5000
Hello, I apologize for the translation, I’m from Brazil and I do not speak English.
I’m setting up a temperature monitor. I found some projects on the internet. I’m going to use this https://easytromlabs.com/arduino/arduino-lab-19-learning-and-datalogger-of-temperature-using-a thermocouple-type-keo-max6675 / but I want to add two more max6675 sensors and one more screen. I can do the assembly but not the code please help me.
MATERIALS
(1x) Arduino Nano (Atmega 328);
(2x) 16 × 2 LCD Display (HD44780 Controller);
(1x) Potentiometer of 4K7 Ohms.
(4x) Type K thermocouple (0 to 600 ° C);
(1x) Memory card module with Shift Level;
(1x) Mini SD Memory Card;
(4x) Thermocouple reading module with MAX6675 (0 to 1024 ° C);
(1x) Protoboard;
Cables for connection in protoboard.
follows the code:
Arduino Lab 19 - Leitura de Termopar tipo K com MAX6675
– IDE do Arduino Versão 1.8.3
– Autor: Eduardo Avelar
– Blog: easytromlabs.com
– email: contato@easytromlabs.com
– Junho, 2018
#include <LiquidCrystal.h>
#include <SPI.h>
#include <SD.h>
const int SO = 2; // MISO - Master Input, Slave Output - Para MAX6675
const int SCLK = 3; // SCLK - Serial Clock line - Para MAX6675
const int CS1 = A3; // CS1 - Chip Select 1 - Para MAX6675
const int CS2 = A2; // CS2 - Chip Select 2 - Para MAX6675
const int chipSelect = 10;// CS do cartão de memória
double sensor1 = 0; // Variável para o sensor 1
double sensor2 = 0; // Variável para o sensor 2
// MOSI - pin 11 no Arduino
// MISO - pin 12 no Arduino
// CLK - pin 13 no Arduino
// CS - pin 10 no Arduino
// Declaração dos pinos do LCD - RS, E, D4, D5, D6, D7, D8,
LiquidCrystal lcd(9, 8, 4, 5, 6, 7);
// Declara dataFile como arquivo para salvar no SD
File dataFile;
// Gera um simbolo de graus
uint8_t degree[8] = {140, 146, 146, 140, 128, 128, 128, 128};
// Protótipo de funções
byte SPIRead(void);
double readThermocouple(int ChipSelect);
void storeSD();
// Declaração do modo como as portas irão operar
pinMode(CS1, OUTPUT);
pinMode(CS2, OUTPUT);
pinMode(SCLK, OUTPUT);
pinMode(SO, INPUT);
digitalWrite(CS1, HIGH);
digitalWrite(CS2, HIGH);
lcd.begin(16, 2);
lcd.createChar(0, degree);
lcd.setCursor(0, 0);
lcd.print(“Inicializando…”);
// Confere se o cartão está presente e operante
if (!SD.begin(chipSelect)) {
lcd.print("Falha no cartao ");
return;
lcd.print("Cartao OK ");
lcd.clear(); // Limpa o display
// Linha 0, coluna 0
lcd.print("Sensor1: ");
sensor1 = readThermocouple(CS1);
lcd.print(sensor1, 1);
lcd.write((byte)0);
lcd.print(“C”);
// Linha 1, coluna 0
lcd.setCursor(0, 1);
lcd.print("Sensor2: ");
sensor2 = readThermocouple(CS2);
lcd.print(sensor2, 1);
lcd.write((byte)0);
lcd.print(“C”);
storeSD(); // Função que faz o armazenamento das leituras no SD
delay(10000); // Aguarda 10 Segundos para uma nova leitura e armazenamento no cartão
// Função para armazenamento dos dados de leitura feitos anteriormente
void storeSD() {
// Formata os dados para serem salvos no Cartão SD a cada 1 segundo
String dataString = “”; // Declara uma string para salvar os dados no SD
dataString += "Sensor1: ";
dataString += String(sensor1); // Valor da leitura do sensor 1
dataString += " °C ";
dataString += "Sensor2: “;
dataString += String(sensor2); // Valor da leitura do sensor 2
dataString += " °C”;
// Abre o arquivo, escreve e o fecha novamente
dataFile = SD.open(“datalog.txt”, FILE_WRITE);
// Se o arquivo esta presente, escreve no mesmo
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// Se o arquivo não abrir, indica no display
else {
lcd.print("Falha ao abrir ");
lcd.print("o arquivo no SD ");
// Função para leitura dos dados de temperatura provindos do MAX6675
double readThermocouple(int ChipSelect) {
uint16_t v; // Declara variável de 16 bits - Tamanho ideal para o dado entregue pelo MAX
digitalWrite(ChipSelect, LOW);
_delay_ms(1);
v = SPIRead(); // Leitura da parte alta - Primeiros 8 bits de dados
v <<= 8; // Desloca 8 posições para a esquerda
v |= SPIRead(); // Faz leitura da parte baixo e armazena nos 8 primeiros bits atravez de uma OR
digitalWrite(ChipSelect, HIGH);
// Confere o bit 2 para termopar acoplado ou não
if (v & 0x4) {
return NAN;
v >>= 3; // Descarta os 3 primeiros bits, onde apenas o bit 2 carrega o status e lê do bit 3 ao 14
return v * 0.25; // Multiplica pela resolução do MAX
// Função que implementa um “SPI” via Software para leitura dos dados no MAX6675
byte SPIRead(void) {
int i;
byte d = 0;
// Laço FOR para apanhar 8 bits de cada vez
for (i = 7; i >= 0; i–)
digitalWrite(SCLK, LOW); // Borda de descida do clock - Falling Edge
_delay_ms(1); // Aguarda 1ms
if (digitalRead(SO)) { // Faz a leitura do pino de dados de saída do MAX
d |= (1 << i); // Armazena os bits lidos, 0 ou 1, na variável e desloca de acordo com o indice para
} // preencher todo o byte de dados
digitalWrite(SCLK, HIGH); // Borda de subida do clock - Rising Edge
return d; // Retirna o byte de leitura dos dados lidos do MAX
thank you so much…
I don't speak Portuguese, but I do know the forum has a Portuguese section
I did not find Portuguese. You can help me.
Here
thank you
