I want to know which model of Audrino board has inbuilt GSM module and connect GAS sensor (CO) ?
The product page on the Arduino site has all that data. YOU go look at which ones contain the hardware you need.
No Arduinos come with such a special purpose sensor built in.
I want to connect GAS sensor- MQ-7 Carbon Monoxide Sensor Circuit Built with an Arduino
should have GSM module to use SIM card for providing internet connectivity
I am not personally aware of an Arduino that has a built in GSM, but I am sure if you go to the Ardunio store, you will be able to assess that yourself.
As far as the sensor, you will not find that sensor on any Arduino.
LaxmanOza:
I want to connect GAS sensor- MQ-7 Carbon Monoxide Sensor Circuit Built with an Arduinoshould have GSM module to use SIM card for providing internet connectivity
The web page in your link explains how to connect the sensor to an Arduino.
You should also be able to connect a suitable GSM module to the same Arduino.
An Arduino Uno is the best for beginners because most software and add ons will work with an Uno.
...R
The Arduino MKR GSM 1400 has an onboard GSM module and uses a SIM card:
