Help me in stepper motor project
Hello, I am interested in using one 5V 4-phase 5-wire Stepper Motor , the cheap one's on ebay.
I have never before used a stepper motor, and here is my question :
Can I directly plug that motor in the arduino board, or I should use a motor controller board as well ?
Thank you for your help !
The 28YBJ-48 steppers are frequently sold with a driver board for around $5. You need that board or would need to build your own -- which would be fairly straightforward using 4 transistors, diodes, and resistors. The Arduino alone is not capable of sourcing the amperage to power the motor and the inductive spikes from any motor needs to be managed as well.
Hello,
I have bought that motor wich you refer to,28BYJ-48 along with a ULN2003 control board. Probably it will work fine,
but I started this topic because in the stepper examples of arduino there's no information about an extra board.
Thank you for your reply
It is described in the reference for the Stepper library: http://arduino.cc/en/Reference/StepperUnipolarCircuit
