Help me on adding another project on previous one
Currently i made a project
https://support.exosite.com/hc/en-us/articles/200095738-Arduino-Basic-Temperature-Monitor
and it work nicely and i like to add DHT11 sensor to check the humidity and i found few sample codes but iam getting error
any idea to add humidity sensor with the existing project ?
code i using now is
 Exosite Arduino Basic Temp Monitor 2 (updated to use Exosite library)
 This sketch shows an example of sending data from a connected
 sensor to Exosite. (http://exosite.com) Code was used from various
 public examples including the Arduino Ethernet examples and the OneWire
 Library examples found on the Arduino playground.
 (OneWire Lib credits to Jim Studt, Tom Pollard, Robin James, and Paul Stoffregen)
 This code keeps track of how many milliseconds have passed
 and after the user defined REPORT_TIMEOUT (default 60 seconds)
 reports the temperature from a Dallas Semi DS18B20 1-wire temp sensor.
 The code sets up the Ethernet client connection and connects / disconnects
 to the Exosite server when sending data.
 Assumptions:
 - Tested with Aruduino 1.0.5
 - Arduino included Ethernet Library
 - Arduino included SPI Library
 - Using Exosite library (2013-10-20) https://github.com/exosite-garage/arduino_exosite_library
 - Using OneWire Library Version 2.0 - http://www.arduino.cc/playground/Learning/OneWire
 - Using Dallas Temperature Control Library - http://download.milesburton.com/Arduino/MaximTemperature/DallasTemperature_372Beta.zip
 - Uses Exosite's basic HTTP API, revision 1.0 https://github.com/exosite/api/tree/master/data
 --- USER MUST DO THE FOLLOWING ---
 - User has an Exosite account and created a device (CIK needed / https://portals.exosite.com -> Add Device)
 - User has added a device to Exosite account and added a data source with alias 'temp', type 'float'
 Hardware:
 - Arduino Duemilanove or similiar
 - Arduino Ethernet Shield
 - Dallas Semiconductor DS18B20 1-Wire Temp sensor used in parasite power mode (on data pin 7, with 4.7k pull-up)
Version History:
- 1.0 - November 8, 2010 - by M. Aanenson
- 2.0 - July 6, 2012 - by M. Aanenson
- 3.0 - October 25, 2013 - by M. Aanenson - Note: Updated to use latest Exosite Arduino Library
#include <EEPROM.h>
#include <SPI.h>
#include <Ethernet.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Exosite.h>
// Pin use
#define ONEWIRE 7 //pin to use for One Wire interface
// Set up which Arduino pin will be used for the 1-wire interface to the sensor
OneWire oneWire(ONEWIRE);
DallasTemperature sensors(&oneWire);
* Configuration Variables
* Change these variables to your own settings.
String cikData = "0000000000000000000000000000000000000000";  // <-- FILL IN YOUR CIK HERE! (https://portals.exosite.com -> Add Device)
byte macData[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};        // <-- FILL IN YOUR Ethernet shield's MAC address here.
// User defined variables for Exosite reporting period and averaging samples
#define REPORT_TIMEOUT 30000 //milliseconds period for reporting to Exosite.com
#define SENSOR_READ_TIMEOUT 5000 //milliseconds period for reading sensors in loop
* End of Configuration Variables
class EthernetClient client;
Exosite exosite(cikData, &client);
// The 'setup()' function is the first function that runs on the Arduino.
// It runs completely and when complete jumps to 'loop()'
  Serial.println("Boot");
  // Start up the OneWire Sensors library
  sensors.begin();
  Serial.println("Starting Exosite Temp Monitor");
  Serial.print("OneWire Digital Pin Specified: ");
  Serial.println(ONEWIRE);
  Ethernet.begin(macData);
  // wait 3 seconds for connection
  delay(3000);
// The 'loop()' function is the 'main' function for Arduino
// and is essentially a constant while loop.
  static unsigned long sendPrevTime = 0;
  static unsigned long sensorPrevTime = 0;
  static float tempF;
  char buffer[7];
  String readParam = "";
  String writeParam = "";
  String returnString = "";
  Serial.print("."); // print to show running
 // Read sensor every defined timeout period
  if (millis() - sensorPrevTime > SENSOR_READ_TIMEOUT) {
    Serial.println("Requesting temperature...");
    sensors.requestTemperatures(); // Send the command to get temperatures
    float tempC = sensors.getTempCByIndex(0);
    Serial.print("Celsius:    ");
    Serial.print(tempC);
    Serial.println(" C ..........DONE");
    tempF = DallasTemperature::toFahrenheit(tempC);
    Serial.print("Fahrenheit: ");
    Serial.print(tempF);
    Serial.println(" F ..........DONE");
    sensorPrevTime = millis();
  // Send to Exosite every defined timeout period
  if (millis() - sendPrevTime > REPORT_TIMEOUT) {
    Serial.println(); //start fresh debug line
    Serial.println("Sending data to Exosite...");
    readParam = "";        //nothing to read back at this time e.g. 'control&status' if you wanted to read those data sources
    writeParam = "temp="; //parameters to write e.g. 'temp=65.54' or 'temp=65.54&status=on'
    String tempValue = dtostrf(tempF, 1, 2, buffer); // convert float to String, minimum size = 1, decimal places = 2
    writeParam += tempValue;    //add converted temperature String value
    //writeParam += "&message=hello"; //add another piece of data to send
    if ( exosite.writeRead(writeParam, readParam, returnString)) {
      Serial.println("Exosite OK");
      if (returnString != "") {
        Serial.println("Response:");
        Serial.println(returnString);
    else {
      Serial.println("Exosite Error");
    sendPrevTime = millis(); //reset report period timer
    Serial.println("done sending.");
  delay(1000); //slow down loop
I don't know much about that sensor, but it looks like there a library for it here: http://playground.arduino.cc/Main/DHT11Lib
To send that data to exosite, you'll need to insert some code at the "//writeParam += "&message=hello"; //add another piece of data to send" line.
It's going to be something along the lines of:
writeParam = "&hum=";  //note the ampersand to seperate each key-value pair
String humValue = dtostrf((float)DHT11.humidity, 1, 2, buffer); // convert float to String, minimum size = 1, decimal places = 2
writeParam += humValue;    //add converted String value
Obviously leaving some stuff out there, like actually doing the read on the sensor, see the library for info. Also, code is untested may kill your cat, bla, bla, bla.
--Patrick@Exosite
Azdle: I don't know much about that sensor, but it looks like there a library for it here: http://playground.arduino.cc/Main/DHT11Lib
--Patrick@Exosite
thanks if i like to add another DS18B20 temp sensor on the same project how can i find the sensor address for 2rd one and how can i add it to the exiting code
I haven't tried it myself, but it should just be a matter of calling sensors.getTempCByIndex(1) and if you add a third it would be sensors.getTempCByIndex(2). Then to upload it to exosite, you can basically copy an paste the three lines that build the writeParam variable. (But add an ampersand and change the dataport alias.)
Azdle: I haven't tried it myself, but it should just be a matter of calling sensors.getTempCByIndex(1) and if you add a third it would be sensors.getTempCByIndex(2). Then to upload it to exosite, you can basically copy an paste the three lines that build the writeParam variable. (But add an ampersand and change the dataport alias.)
thanks let me try this btw we dont need to find the address of 2rd DS18B20 ? will sensors.getTempCByIndex(1) can work ? will it detect the 2rd temp sensor ?
You can use getTempCByIndex without knowing the sensor's address. The library can find all the sensors on the bus, which enables this behavior.
There are two problems though: firstly, which sensor is which is not obvious. getTempCByIndex(0) will always get the same one, but it may be the one furthest from the arduino - it's tempting to think that the physical distance from the arduino controls this but it doesn't.
Worse, if you add a sensor or replace one, the order can change. Best therefore to stick with using the addresses.
I have that very sensor rigged up for an incubator. Dead easy.
At the top of my sketch I have
#include <dht11.h>
Then the part that reads humidity is just
dht11 DHT11;
int chk=DHT11.read(53);//53 IS THE DATA PIN IT'S CONNECTED TO
if (chk!=DHTLIB_OK)
  sysHumidity=-1;          //I use -1 to signal failure to read.  Doesn't happen under normal circumstances
  sysHumidity=(int)DHT11.humidity;
//SysHumidity now holds the humidity reading.
//Simple as that!
I can’t remember where I got the library from but it’s called DHT11
If you want I can post the .H and .CPP files (There pretty small)
