help me on making the "NEXT" and "PREVIOUS" button for the LED patterns
hello, im trying to make a program that, when i click button 1 it will move to NEXT state and when i press button 2 it will move to PREVIOUS state, i already tried look at some example but it work for NEXT only not on PREVIOUS, please help me…
Thanks…
sketch_may04a.ino (1.3 KB)
Have you read about State Machines?
Work on and add to this example:
byte led1 = 13;
byte led2 = 12;
byte button1 = 2;
byte button2 = 3;
//define the available states that we can have for this sketch
enum States{
  stateOne, stateTwo};
//add more states as needed
States mState = stateOne;             //we start out in this machine state
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  digitalWrite(led1,LOW);
  digitalWrite(led2,HIGH);
} //END of setup()
  switch (mState)
  case stateOne:
      if(digitalRead(button1)) // or use:  if(!digitalRead(button1))
        digitalWrite(led1,HIGH);
        digitalWrite(led2,LOW);
        mState = stateTwo;
  case stateTwo:
      if(digitalRead(button2)) // or use:  if(!digitalRead(button2))
        mState = stateOne;
  default:
    // default code goes here
  } //END of switch(mState)
} //END of loop()
I do read about the state machine but the code i make in order for it to be able to back on PREVIOUS state was not working, ill try the example that you gave to me.. thanks in advance.. but if i have 20+ state how do i control it with button 1 and button 2 so that i can make it go NEXT and back to PREVIOUS?
You can add the number of states you need. Start small, add code as needed once things are working.
Example: When you are in state 12 and button 2 is pushed then you set the state to 13 etc. If you are in state 13 and you push button 1 then you set the state to 12 etc.
