Help me out Quickly please!!!!
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 1958 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 223 bytes (10%) of dynamic memory, leaving 1825 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Shahzad\AppData\Local\Temp\arduino_build_605373/relay-led.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM3": The semaphore timeout period has expired.
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Do you have a question?
yes !!! when ever i upload code to board it gives mean error. I change serial port to resolve the issue also set the preference upload setting but doesn't get the desire result . Please let me know what to do next?
@kqibtiya5
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
sorry for that sir. I will make it sure not to waste your time. I tried all possible solution regarding to this but I can't solve my problem.
You may have something else connected to that con port ( eg a blue tooth device, printer whatever ) or the Arduino isn’t actually on that port .
Unplug it / plug it in and see which port disappears /appears in tools/port menu to correctly identify the port .
