//declare variables for the motor pins
int motorPin1 = 8; // Blue - 28BYJ48 pin 1
int motorPin2 = 9; // Pink - 28BYJ48 pin 2
int motorPin3 = 10; // Yellow - 28BYJ48 pin 3
int motorPin4 = 11; // Orange - 28BYJ48 pin 4
// Red - 28BYJ48 pin 5 (VCC)
int motorSpeed = 0; //variable to set stepper speed
int sensorValue = 0; //potentiometer connected to A0
long int currentMillis;
boolean motorRunning = false;
unsigned long motorStartMillis;
unsigned long motorRunMillis = 180000;
//declare the motor pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
void loop(){
sensorValue = analogRead(A0); // read the value of the potentiometer
Serial.println(sensorValue); // View full range from 0 - 1024 in Serial Monitor
if (sensorValue < 300){ // if potentiometer reads 0 to 535 do this
motorSpeed = (1); //scale potValue to be useful for motor
clockwise(); //go to the ccw rotation function
delay(0);
if (sensorValue > 700){ // if potentiometer reads 0 to 535 do this
delay(0);
else { //value of the potentiometer is 512 - 1024
motorSpeed = (1); //scale potValue for motor speed
counterclockwise(); //go the the cw rotation function
delay(0);
//set pins to ULN2003 high in sequence from 1 to 4
//delay “motorSpeed” between each pin setting (to determine speed)
void counterclockwise (){
// 1
digitalWrite(motorPin1, HIGH);
digitalWrite(motorPin2, LOW);
digitalWrite(motorPin3, LOW);
digitalWrite(motorPin4, LOW);
delay(motorSpeed);
// 2
digitalWrite(motorPin2, HIGH);
delay (motorSpeed);
// 3
digitalWrite(motorPin1, LOW);
delay(motorSpeed);
// 4
digitalWrite(motorPin3, HIGH);
delay(motorSpeed);
// 5
delay(motorSpeed);
// 6
digitalWrite(motorPin4, HIGH);
delay (motorSpeed);
// 7
delay(motorSpeed);
// 8
delay(motorSpeed);
//set pins to ULN2003 high in sequence from 4 to 1
void clockwise(){
// 1
delay(motorSpeed);
// 2
delay (motorSpeed);
// 3
delay(motorSpeed);
// 4
delay(motorSpeed);
// 5
delay(motorSpeed);
// 6
delay (motorSpeed);
// 7
delay(motorSpeed);
// 8
delay(motorSpeed);
