help me please!!!
Thank you for Reading this post!
I’m sorry to say that i don’t write Englich well.
Maybe, you don’t understand my word.
sorry!
What should i do to link between arduino and processing?
int switchPin = 4;
void setup(){
pinMode(switchPin, INPUT);
if(digitalRead(switchPin) == HIGH) {
Serial.print(1,BYTE);
else {
Serial.print(0,BYTE);
delay(100);
import processing.serial.*;
Serial port;
int val;
size(200,200);
frameRate(10);
port = new Serial(this, 9600);
void draw() {
if(0 > port.available()) {
val = port.read();
background(255);
if (val == 0) {
fill(0);
else {
fill(204);
rect(50,50,100,100);
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
This example is in the Processing Handbook from the MIT press.
when i code “blink” . It does work.
i think arduino and computer are related each other.
But arduino and processin aren’t realated each other.
what should i do ?
