i m using arduino for my project and i used a l293D to turn it in both ways but i want to turn the motor for 2 second
what is the code for that
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
int led = 4;
int ledPin1=12;
int motor1Pin1 = 3; // pin 2 (Input 1) du L293D
int motor1Pin2 = 4; // pin 7 (Input 2) du L293D
int enablePin = 9; // pin 1 (Enable 1) du L293D
Servo microservo;
int pos = 0;
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip = { 192, 168, 1, 178 }; // ip in lan (that’s what you need to use in your browser. (“192.168.1.178”)
byte gateway = { 192, 168, 1, 1 }; // internet access via router
byte subnet = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;void setup() {
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
pinMode(led, OUTPUT);
microservo.attach(7);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
}void loop() {
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
}//if HTTP request has ended
if (c == ‘\n’) {
Serial.println(readString); //print to serial monitor for debugingclient.println(“HTTP/1.1 200 OK”); //send new page
client.println(“Content-Type: text/html”);
client.println();
client.println("");
client.println("");
client.println("");
client.println("");
client.println("");
client.println(“commande a distance d’un portail”);
client.println("");
client.println("");
client.println(“Commande a distance d’un eclairage et d’un portail electrique
client.println("
client.println("
client.println(“Arduino with Ethernet Shield
client.println(”
client.println(”kais boussadia
client.println(”");
client.println(“
projet fin d’etude -isitcom
client.println(”
client.println(”
client.println(”<a href=”/?button1on"">allumer eclairage");
client.println("
client.println(”
client.println(”
client.println(”<a href="/?button1off"">eteindre eclairage
client.println(”
client.println(”
client.println(”<a href="/?button2on""> ouvrir portail “);
client.println(”
client.println(”
client.println(”
");client.println("<a href="/?button2off""> fermer portail
");client.println("
client.println(”");
client.println("");delay(1);
//stopping client
client.stop();
//controls the Arduino if you press the buttons
if (readString.indexOf("?button1on") >0){
digitalWrite(led, HIGH);
digitalWrite(ledPin1,HIGH);
if (readString.indexOf("?button1off") >0){
digitalWrite(led, LOW);
digitalWrite(ledPin1,LOW);
if (readString.indexOf("?button2on") >0){
for(pos = 0; pos < 360; pos += 4) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
microservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(15); // waits 15ms for the servo to reach the position
if (readString.indexOf("?button2off") >0){
for(pos = 360; pos>=1; pos-=4) // goes from 180 degrees to 0 degrees
//clearing string for next read
readString="";}
i need to change this code for my DC motor instead of servomoteur
