Help me reuse A3967 Microstepper Driver
First of all here be the datasheet - (https://datasheet.octopart.com/A3967SLBTR-T-Allegro-MicroSystems-LLC-datasheet-7603684.pdf)
And images - (Imgur: The magic of the Internet | Imgur: The magic of the Internet)
Hello everyone and thank you in advance for your time.
So last night i looked at the main board of an 2006 HP copier, and to my surprise i found a A3967 Microstepper Driver on there (i have the original stepper that came with it), it seems to have no need for a darlington array to drive the stepper, so i looked it up and from the data sheet info it seems that it would be an easy hack, but i wanted to make sure since it has many pins with various functions like, SLEEP, RESET, ENABLE.
My questions for you are, how should i aproach this hack? i tried to use it with an ESP8266 (not from PWM pins, also its all i have in hand) running a basic loop with steps and direction (as it suggests in the datasheet, it should be that easy). But there are just too many factors while its on that main board. I did not touch anything from the main board it was on, the driver is getting 3V into VCC logic supply and all seems good, and that was the main reason i did not touch it. My next idea was to cut the traces from some pins like those mentioned above with the functions that MAY or may NOT be making me a hustle, and control them from the arduino.
Now it is late and im sure i could provide you with more info, please bare with me and let me know what else you might need from me.
Sorry if im in the wrong place, i could not decide between here and the hack section.
Study the A3967 data sheet very carefully, and check out one or more of the many tutorials on line.
I believe the Sparkfun Easydriver board uses the A3967. You may get some ideas from their website. It probably has a schematic.
...R
