We are working on a project for graduation using Arduino.
We are in the process of measuring the heart rate using WEMOS D1, and AD8232, HC06 and storing the measured heart rate in the firebase, but it is not stored in the firebase. Help me
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
SoftwareSerial BTSerial(2,3);
#define FIREBASE_HOST ""
#define FIREBASE_AUTH ""
#define WIFI_SSID ""
#define WIFI_PASSWORD ""
int UpperThreshold = 518;
int LowerThreshold = 490;
int reading = 0;
float BPM = 0.0;
bool IgnoreReading = false;
bool FirstPulseDetected = false;
unsigned long FirstPulseTime = 0;
unsigned long SecondPulseTime = 0;
unsigned long PulseInterval = 0;
// qsort를 사용해 중간 값을 찾는 코드
int compare(const void *f1, const void *f2)
return (*(double*)f1 > *(double*)f2) ? 1 : -1;
double get_qsort_median(double *data, int n)
if (!data) return 0;
qsort(data, n, sizeof(double), compare);
return data[n / 2];
// loop를 돌며 데이터를 정렬하여 중간 값을 찾는 코드
double get_median(double *data, int n)
#define swap(a,b) {double temp = a;a=b;b=temp;}
int i = 0;
int j = 0;
i = n - 1;
while (i > 0)
j = 0;
while (j < i)
if (data[j] > data[j + 1]) swap(data[j], data[j + 1]);
j++;
i--;
return data[n / 2];
int median_filter(double *in, double *out, int n)
#define window_size 3
double temp[window_size] = { 0, };
int i = 0;
if (!in || !out || n < window_size)
return -1;
for (i = window_size / 2; i < n - window_size / 2; i++)
memcpy(temp, &in[i - window_size / 2], window_size * sizeof(double));
out[i] = get_qsort_median(temp, window_size);
return 0;
void setup(){
BTSerial.begin(9600);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("connecting");
Serial.print(".");
Serial.print("connected: ");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
pinMode(10, INPUT); // Setup for leads off detection LO +
pinMode(11, INPUT); // Setup for leads off detection LO -
pinMode(A0, OUTPUT);
int n = 0;
void loop(){
// set value
Firebase.setFloat("BeatPerMin", 0.0);
// handle error
if (Firebase.failed()) {
Serial.print("setting /BeatPerMin save failed:");
Serial.println(Firebase.error());
return;
reading = analogRead(0);
// Heart beat leading edge detected.
if(reading > UpperThreshold && IgnoreReading == false){
if(FirstPulseDetected == false){
FirstPulseTime = millis();
FirstPulseDetected = true;
else{
SecondPulseTime = millis();
PulseInterval = SecondPulseTime - FirstPulseTime;
IgnoreReading = true;
// Heart beat trailing edge detected.
if(reading < LowerThreshold){
BPM = (60.0/PulseInterval);
reading == BPM;
Serial.print(reading);
Serial.print("\n");
BTSerial.print(reading);
Serial.flush();
// Please don't use delay() - this is just for testing purposes.
// update value
Firebase.setFloat("BeatPerMin", reading);
// handle error
return;
float ECGFilter(float input)
float output = input;
static float z1, z2; // filter section state
float x = output - 0.70682283*z1 - 0.15621030*z2;
output = 0.28064917*x + 0.56129834*z1 + 0.28064917*z2;
z2 = z1;
z1 = x;
float x = output - 0.95028224*z1 - 0.54073140*z2;
output = 1.00000000*x + 2.00000000*z1 + 1.00000000*z2;
z2 = z1;
z1 = x;
float x = output - -1.95360385*z1 - 0.95423412*z2;
output = 1.00000000*x + -2.00000000*z1 + 1.00000000*z2;
z2 = z1;
z1 = x;
float x = output - -1.98048558*z1 - 0.98111344*z2;
z2 = z1;
z1 = x;
return output;
Compiling results in the following error:
아두이노:1.8.19 (Windows 10), 보드:"LOLIN(WeMos) D1 R1, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 57600"
C:\Users\leedo\OneDrive\����\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&)':
C:\Users\leedo\OneDrive\����\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:27:50: error: no matching function for call to 'begin(const char*, const char [60])'
27 | http_.begin(url.c_str(), kFirebaseFingerprint);
In file included from C:\Users\leedo\OneDrive\����\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:9:
C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: candidate: 'bool HTTPClient::begin(String, uint16_t, String)' (near match)
166 | bool begin(String host, uint16_t port, String uri = "/") attribute ((error("obsolete API, use ::begin(WiFiClient, host, port, uri)")));
C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: conversion of argument 2 would be ill-formed:
C:\Users\leedo\OneDrive\����\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:27:30: error: invalid conversion from 'const char*' to 'uint16_t' {aka 'short unsigned int'} [-fpermissive]
| const char*
C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: candidate: 'bool HTTPClient::begin(String, const uint8_t*)' (near match)
167 | bool begin(String url, const uint8_t httpsFingerprint[20]) attribute ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: conversion of argument 2 would be ill-formed:
C:\Users\leedo\OneDrive\����\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:27:30: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
| const char*
C:\Users\leedo\OneDrive\����\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&, const string&)':
C:\Users\leedo\OneDrive\����\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:31:60: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
31 | http_.begin(host.c_str(), kFirebasePort, path.c_str(), kFirebaseFingerprint);
| const char*
C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:168:70: note: initializing argument 4 of 'bool HTTPClient::begin(String, uint16_t, String, const uint8_t*)'
168 | bool begin(String host, uint16_t port, String uri, const uint8_t httpsFingerprint[20]) attribute ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
exit status 1
보드 LOLIN(WeMos) D1 R1 컴파일 에러.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\leedo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\leedo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\leedo\OneDrive\문서\Arduino\libraries -fqbn=esp8266:esp8266:d1:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=57600 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\leedo\AppData\Local\Temp\arduino_build_367671 -warnings=none -build-cache C:\Users\leedo\AppData\Local\Temp\arduino_cache_689418 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Users\leedo\OneDrive\바탕 화면\ECG\ECG.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\leedo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\leedo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\leedo\OneDrive\문서\Arduino\libraries -fqbn=esp8266:esp8266:d1:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=57600 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\leedo\AppData\Local\Temp\arduino_build_367671 -warnings=none -build-cache C:\Users\leedo\AppData\Local\Temp\arduino_cache_689418 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Users\leedo\OneDrive\바탕 화면\ECG\ECG.ino
Using board 'd1' from platform in folder: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\sketch\ECG.ino.cpp" -o nul
Alternatives for SoftwareSerial.h: [SoftwareSerial@6.12.7]
ResolveLibrary(SoftwareSerial.h)
-> candidates: [SoftwareSerial@6.12.7]
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\sketch\ECG.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\sketch\ECG.ino.cpp" -o nul
Alternatives for FirebaseArduino.h: [firebase-arduino-master@0.1]
ResolveLibrary(FirebaseArduino.h)
-> candidates: [firebase-arduino-master@0.1]
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\sketch\ECG.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src\SoftwareSerial.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\BearSSLHelpers.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiGratuitous.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiClient.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiClientSecureBearSSL.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiServer.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiServerSecureBearSSL.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiUdp.cpp
Using cached library dependencies for file: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\enable_wifi_at_boot_time.cpp
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\Firebase.cpp" -o nul
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseArduino.cpp" -o nul
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseCloudMessaging.cpp" -o nul
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp" -o nul
Alternatives for ESP8266HTTPClient.h: [ESP8266HTTPClient@1.2]
ResolveLibrary(ESP8266HTTPClient.h)
-> candidates: [ESP8266HTTPClient@1.2]
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp" -o nul
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseObject.cpp" -o nul
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\throw_out_of_range.cpp" -o nul
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp" -o nul
Generating function prototypes...
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\sketch\ECG.ino.cpp" -o "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\preproc\ctags_target_for_gcc_minus_e.cpp"
스케치를 컴파일 중…
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/signing.py" --mode header --publickey "C:\Users\leedo\OneDrive\바탕 화면\ECG/public.key" --out "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core/Updater_Signing.h"
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\sketch\ECG.ino.cpp" -o "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\sketch\ECG.ino.cpp.o"
Compiling libraries...
Compiling library "SoftwareSerial"
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\SoftwareSerial\SoftwareSerial.cpp.o 사용
Compiling library "ESP8266WiFi"
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFiGratuitous.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\BearSSLHelpers.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\CertStoreBearSSL.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFiSTA-WPS.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\WiFiClient.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\WiFiServer.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\WiFiClientSecureBearSSL.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\WiFiUdp.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\enable_wifi_at_boot_time.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\WiFiServerSecureBearSSL.cpp.o 사용
이전에 컴파일된 파일: C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\ESP8266WiFi\ESP8266WiFi.a 사용
Compiling library "firebase-arduino-master"
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\Firebase.cpp" -o "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\firebase-arduino-master\Firebase.cpp.o"
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp" -o "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\firebase-arduino-master\FirebaseHttpClient_Esp8266.cpp.o"
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseObject.cpp" -o "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\firebase-arduino-master\FirebaseObject.cpp.o"
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseArduino.cpp" -o "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\firebase-arduino-master\FirebaseArduino.cpp.o"
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\throw_out_of_range.cpp" -o "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\firebase-arduino-master\throw_out_of_range.cpp.o"
"C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\leedo\AppData\Local\Temp\arduino_build_367671/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1R1"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\d1" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "-IC:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src" "-IC:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src" "C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master\src\FirebaseCloudMessaging.cpp" -o "C:\Users\leedo\AppData\Local\Temp\arduino_build_367671\libraries\firebase-arduino-master\FirebaseCloudMessaging.cpp.o"
| const char*
| const char*
| const char*
라이브러리 SoftwareSerial를 버전 6.12.7 폴더: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial 에서 사용
라이브러리 ESP8266WiFi를 버전 1.0 폴더: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi 에서 사용
라이브러리 firebase-arduino-master를 버전 0.1 폴더: C:\Users\leedo\OneDrive\문서\Arduino\libraries\firebase-arduino-master 에서 사용
라이브러리 ESP8266HTTPClient를 버전 1.2 폴더: C:\Users\leedo\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient 에서 사용
exit status 1
