Help me! T_T! Ardunio Pro mini error:avrdude: stk500_getsync() attempt 1 of 10
I used Ardunio mini pro + 6050 + MPU data PL2303HX to connect to the computer. Truth GND, VCC 5V power supply, connect TXO TXD, RXD RXI connection. When uploading data error avrdude: stk500_getsync () cố 1 of 10. When retry Arduino: 1.6.1 (Windows 7), the Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
Sketch dùng 4.138 bytes (13%) of storage space program. Maximum is 30.720 bytes.
Global variables use 508 bytes (24%) of dynamic memory, Leaving 1,540 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_recv (): programmer is not responding
avrdude: stk500_getsync () cố 1 of 10: not in sync: resp = 0x75
avrdude: stk500_getsync () cố 2 of 10: not in sync: resp = 0x75
avrdude: stk500_getsync () cố 3 of 10: not in sync: resp = 0x75
avrdude: stk500_getsync () cố 4 of 10: not in sync: resp = 0x75
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync () cố 5 of 10: not in sync: resp = 0x75
avrdude: stk500_getsync () cố 6 of 10: not in sync: resp = 0x75
avrdude: stk500_getsync () cố 7 of 10: not in sync: resp = 0x75
avrdude: stk500_getsync () cố 8 of 10: not in sync: resp = 0x75
avrdude: stk500_getsync () cố 9 of 10: not in sync: resp = 0x75
avrdude: stk500_getsync () cố 10 of 10: not in sync: resp = 0x75
This report would have more information with "Show verbose output the during compilation" enabled in File> Preferences. . Please help me?
Ok... You could have a number of problems. Check the USB to serial board is recognised first.
Without it plugged in, look under tools->port in the IDE.
Then plug it in and check again. You should see a new port. If you do use it, if not you have a driver issue.
If you can see the port then it is probably a wiring issue. TX and RX need to be crossed to TX on one goes to RX on the other. Check reset is wired.
press 'reset' shortly just as upload starts
